[GeoNetwork-devel] Metadata editor refactoring
We’re about to propose the new metadata editor for vote.
https://github.com/geonetwork/core-geonetwork/wiki/Refactoring-editor
We’ll be on IRC this morning, if anyone want to discuss it in more details.
Cheers.
Francois
Francois,
I've been following the commits - looks good! Naturally, I'm keen to solve the widget injection from a schema plugin :-).
Cheers and thanks,
Simon
________________________________________
From: Francois Prunayre [fx.prunayre@anonymised.com]
Sent: Tuesday, 28 January 2014 8:23 PM
To: Devel geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Metadata editor refactoring
We're about to propose the new metadata editor for vote.
We'll be on IRC this morning, if anyone want to discuss it in more details.
Cheers.
Francois
With the new javascript build system it would be easy to change the wro4j factory to check the schema plugins folder for wroj-sources.xml files and add them to the configuration automatically. I think that would be sufficient for widget injection right?
On Tue, Jan 28, 2014 at 11:39 AM, <Simon.Pigot@anonymised.com> wrote:
Francois,
I’ve been following the commits - looks good! Naturally, I’m keen to solve the widget injection from a schema plugin :-).
Cheers and thanks,
Simon
Cheers.
Francois
WatchGuard Dimension instantly turns raw network data into actionable
security intelligence. It gives you real-time visual feedback on key
security issues and trends. Skip the complicated setup - simply import
a virtual appliance and go from zero to informed in seconds.
http://pubads.g.doubleclick.net/gampad/clk?id=123612991&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
