[GeoNetwork-devel] Metadata Exchange Format
Hi Andrea, I think the schema parameter could be useful.
If you want, I could work on the user interface (in the administration tab)
to do "batch export of metedata" using the xml.mef.export services ? I
should be able to work on that this month.
One more question on the export services, the harvesting will use that also.
Is version 2.1 will be able to harwest 2.0 nodes ? Maybe yes but not
thumbnails...
Ciao. Francois
-----Message d'origine-----
De : geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de Andrea
Carboni Envoyé : mardi 28 novembre 2006 19:16 À :
geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] Metadata Exchange Format
Hi Francois,
I won't consider the short term perspective but about the long term one, I
have these 2 considerations:
- In my vision, the metadata should be exported 'as is' and the
transformation
  should be done in the client/import procedure side. This imply that the
  client 'knows' the metadata format and how to transform it. This means
that
  the stylesheets must be moved to the client but this way I cannot create a
  new profile remotely and hope that the client understands it: it is
reasonable
  that the node that creates a profile is also responsible for creating the
stylesheets.
- We could add a 'schema' parameter to the xml.mef.export. If missing, the
metadata
  is exported as is, otherwise geonetwork will try to convert the metadata
into the
  specified format. This can be done this way: beside the xml/schemas folder
(which
  contains dublin-core, fgdc, iso19139 etc...) we could add another one
containing
  subfolders like <schema1>-to-<schema2>. Each subfolder will contain the
stylesheets
  to convert the metadata from schema1 to schema2. Finding the proper
stylesheets
  to use (if any) is simple and this way the xml.mef.export interface should
have a
  behaviour similar to the CSW part.
Hi Andrea, I think it could be usefull regarding two point of view :
- in a short term perspective, actually this could be useful to
migrate from an ISO19115 node to an ISO19139. But we also have a
migrate procedure which has been developped.
- in a long term perspective, I think in the coming month or year we
will have an awesome number of profils based on ISO19139 or ISO19115
(which will be national one, thematics, european, and so on ... ). And
when we will try to exchange metadata between nodes we will have
bottleneck dealing with 'profiling'. Then we will expect to have a
common based format (which will certainly be the core ISO19139).
Currently, Geonetwork is easily configurable to set up a new profil
... And I expect that a lot of users will do so (France has ;). In
such a situation, if Geonetwork is able to at least do a MEF export to
a common based format (well known by all nodes) that could be really
useful.
Then we will have to explain to users that when creating their own
profil in Geonetwork, the last step will be to define an XSL
transformation between the user's profil and the ISO19139 if they want
to be able to speak with other nodes ....
Thoughts ?
Francois
Andrea Carboni Envoyé : vendredi 24 novembre 2006 19:43 À :
Hi François,
now there are 2 xml services: xml.mef.import (to do) and
xml.mef.export (done).
The export service is intended to export one metadata at a time and
can be called by an upper level exporter. Now it accepts the following
parameters:
- 'uuid' : uuid of the metadata
- 'format' : export format among {simple, partial, full}. (simple is
with no thumbnails).
Adding an xsl transformation is feasible: a client could provide the
stylesheet using a local file on the server or embedding it into the
request. I don't know if this could be usefull. For example, into the
info.xml file there is the metadata schema: should I change this value
if I execute an XSL transformation ? Which should be the new value ?
Any comments?
> Hi Andrea, how do you plan to build the interface for metadata export ?
> Could we imagine to be able to apply a stylesheet before creating
> the MEF file ? For example, allow user to select metadata based on
> iso19115 schema, select the one user wants to export and then make a
> batch export in an
> iso19139 schema ...
> Francois
> de Andrea Carboni Envoyé : lundi 13 novembre 2006 18:46 À :
> Objet : [GeoNetwork-devel] Metadata Exchange Format
> Hi all,
> here is a small PDF (4 pages) describing a file format to
> import/export metadata and data.
> I'm starting to implement it but I would like some feedback from you
> in order to make it better. The budget to implement it has already
> been istantiated so it is difficult to make heavy changes but we can
> discuss them anyway.
> Any feedback is welcome.
> Have a good reading,
> Andrea
> Ce message a ete verifie par MailScanner pour des virus ou des
> polluriels et rien de suspect n'a ete trouve.
> Les donnees et renseignements contenus dans ce message sont
> personnels, confidentiels et prives. Toute publication, utilisation
> ou diffusion, meme partielle, doit etre autorisee.
> Any data and information contained in this electronic mail is
> personal, confidential and secret. Any total or partial publication,
> use or distribution must be authorized.
--- Take Surveys. Earn Cash. Influence the Future of IT Join
SourceForge.net's Techsay panel and you'll get the chance to share
your opinions on IT & business topics through brief surveys - and earn
cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEV
DEV _______________________________________________
GeoNetwork-devel mailing list
personnels, confidentiels et prives. Toute publication, utilisation ou
Take Surveys. Earn Cash. Influence the Future of IT Join SourceForge.net's
Techsay panel and you'll get the chance to share your opinions on IT &
business topics through brief surveys - and earn cash
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et
Les donnees et renseignements contenus dans ce message sont personnels,
confidentiels et prives. Toute publication, utilisation ou diffusion, meme
Any data and information contained in this electronic mail is personal,
confidential and secret. Any total or partial publication, use or
Ce message a ete verifie par MailScanner pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et prives. Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and secret. Any total or partial publication, use or distribution must be authorized.
