Just had a quick look at this: it seems that the schemaLocation in the schema-ident.xml file should be set to nothing ie. <gns:schemaLocation/>. This will trigger creation of a noNamespaceSchemaLocation attribute set to the URL of the schema.xsd file for the dublin-core schema files used in GeoNetwork eg.
xsi:noNamespaceSchemaLocation="http://localhost:8080/geonetwork/xml/schemas/dublin-core/schema.xsd
This file includes the dct namespace and thus records that use that namespace will (and do) validate against that.
Don't think this needs any fix apart from that - though in passing I thought it would be nice to get the schemaLocation/noNamespaceSchemaLocation from the schema and put it into the xpath environment passed to update-fixed-info.xsl so that it can be used there without the need to replicate it.
This fix should be a lot easier than switching all our dc stuff from simpledc root element to qualifieddc?
Simon
________________________________________
Sent: Friday, 14 September 2012 4:37 AM
To: Tomas Kliment
Cc: GeoNetwork GeoNetwork Developer list
Subject: Re: [GeoNetwork-devel] - Metadata export generates invalid XML Dublin Core file
Do you think you could make a fork in your github account and push your changes there so I can clone it and try it out myself?
I would be happy to help tomorrow (friday) if you do that.
Jesse
On Thu, Sep 13, 2012 at 4:47 PM, Tomas Kliment <tomas.kliment@anonymised.com<mailto:tomas.kliment@anonymised.com>> wrote:
Yes, I found them, concretely this file: xml_dc.xsl
I changed the root from original simpledc to qualifieddc as follows:
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:template match="/root">
<xsl:apply-templates select="qualifieddc"/>
</xsl:template>
<xsl:template match="@*|node()">
<xsl:copy>
<xsl:apply-templates select="@*|node()[name(self::*)!='geonet:info']"/>
</xsl:copy>
</xsl:template>
</xsl:stylesheet>
However this makes it not possible to be parsed:
XML Parsing Error: no element found
Location: http://localhost:8080/geonetwork-branch-2012-07-25/srv/eng/xml_dublin-core?uuid=306e2a11-cdda-4e18-b31b-0e314728d19c
Line Number 1, Column 39:<?xml version="1.0" encoding="UTF-8"?>
What I do not understand from where this xsl selects it? I guess that it should be from xsl, which presents element in the editor interface, or not?
Tomas
On 13 September 2012 15:33, Jesse Eichar <jesse.eichar@anonymised.com<mailto:jesse.eichar@anonymised.com>> wrote:
I think the export xsl files are in : web/src/main/webapp/xsl/conversion/export
Jesse
On Thu, Sep 13, 2012 at 2:36 PM, Tomas Kliment <tomas.kliment@anonymised.com<mailto:tomas.kliment@anonymised.com>> wrote:
Hi Jesse,
I have opened a ticket pointing out this issue here: #1047 (Metadata export generates invalid XML Dublin Core file) – GeoNetwork opensource Developer website
Meanwhile I tried to change the root and schemaLocation values within the XML and XSLT files related to Dublin Core schema (geonetwork/WEB-INF/data/config/schema_plugins/dublin-core/*.xml/xsl/xsd
I succeeded in changing the schemaLocation URL from changing it in schema-conversion.xml and schema-ident.xml.
However, I could not find the way how to change the root in export.
Any ideas, hints?
Tomas
On 13 September 2012 12:49, Jesse Eichar <jesse.eichar@anonymised.com<mailto:jesse.eichar@anonymised.com>> wrote:
Could you make a trac ticket with this issue? It looks like a good candidate to me. Although I admit I don't use dublin core so often.
Jesse
On Thu, Sep 13, 2012 at 11:51 AM, Tomas Kliment <tomas.kliment@anonymised.com<mailto:tomas.kliment@anonymised.com>> wrote:
Dear all,
I would like to ask you why GeoNetwork generates invalid Dublin Core XML file?
I have created a testing record using GN metadata editor - Dublin Core metadata template:
The export to XML is pasted here:
<simpledc xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:dct="DCMI: DCMI Metadata Terms; xmlns:geonet="http://www.fao.org/geonetwork" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="http://www.dublincore.org/schemas/xmls/qdc/2008/02/11/simpledc.xsd">
<dc:title>TESTING MD RECORD</dc:title>
<dc:creator>TOMAS KLIMENT</dc:creator>
<dc:subject>TEST</dc:subject>
<dc:subject>JRC</dc:subject>
<dc:description>DESCRIPTION</dc:description>
<dc:publisher>KLIMENT</dc:publisher>
<dc:type>testing resource</dc:type>
<dc:format>text/plain</dc:format>
<dc:language>eng</dc:language>
<dc:relation>http://…</dc:relation>
<dc:coverage>North 90, South -90, East 180, West -180. Global</dc:coverage>
<dc:rights>Fre for testing</dc:rights>
<dct:created>now</dct:created>
<dct:dateSubmitted>tomorrow</dct:dateSubmitted>
<dct:modified>2012-09-13T11:39:44</dct:modified>
<dc:identifier>8352f5b4-8be4-4f69-820c-da810f24b988</dc:identifier>
</simpledc>
However it assigns to a schemaLocation attribute simpledc schema, which does not allow elements from dct namespace (dct:created, dct:dateSubmitted etc) thus it causes validation errors:
Element <dct:created> is not allowed under element <simpledc>.
Reason: The following elements are expected at this location (see below)
<relation>
<creator>
<title>
<format>
<rights>
<identifier>
<subject>
<type>
<source>
<publisher>
<contributor>
<language>
<coverage>
<description>
<date>
Annotations of type 'dc:elementContainer' (see below)
This complexType is included as a convenience for schema authors who need to define a root
or container element for all of the DC elements.
Error location: simpledc / dct:created
Details
cvc-model-group: Element <dct:created> unexpected by type 'dc:elementContainer' of element <simpledc>.
cvc-elt.5.2.1: The element <simpledc> is not valid with respect to the actual type definition 'dc:elementContainer'.
One solution how to resolve this would be to change the schemaLocation and root as follows:
<qualifieddc xmlns:dc="DCMI: DCMI Metadata Terms; xmlns:dct="DCMI: DCMI Metadata Terms;
xsi:noNamespaceSchemaLocation="http://dublincore.org/schemas/xmls/qdc/2008/02/11/qualifieddc.xsd" >
</qualifieddc>
To change the Root element from <simpledc> to <qualifieddc> and schemaLocation to point to qualifieddc.xsd schema.
What would you suggest me? Is this already known issue?
Many thanks in advance for any response,
Best regards,
Ing. Tomas Kliment
Contact information:
Private:
Juzna 4, 04801 Roznava, Slovakia
Tel: +421 907 232019<tel:%2B421%20907%20232019>
Tel: +39 389 4955 954<tel:%2B39%20389%204955%20954>
e-mail: tomas.kliment@anonymised.com<mailto:tomas.kliment@anonymised.com>
www: Tomáš Kliment - Zagreb, Grad Zagreb, Croatia, University of Zagreb, Doctor (PhD) in Geodesy and Cartography | about.me
Ph.D. student:
Slovak University of Technology
Faculty of Civil Engineering
Department of Theoretical Geodesy
Radlinskeho 11, block A, 5th floor
813 68 Bratislava 15, Slovakia
Tel: +421 259274 297<tel:%2B421%20259274%20297>
Ph.D. Internship - Junior Researcher:
The National Research Council
Institute of Marine Science, Venice, Italy
External consultant:
Polymedia S.p.A, KIT Digital Company
Joint Research Centre of European Commission, Ispra, Italy
Live Security Virtual Conference
Exclusive live event will cover all the ways today's security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
GeoNetwork-devel@lists.sourceforge.net<mailto:GeoNetwork-devel@anonymised.comforge.net>
geonetwork-devel List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Ing. Tomas Kliment
Private:
Ph.D. student:
Ing. Tomas Kliment
Private:
Ph.D. student:
