Is the metadata status option in the advanced search still working? I just
did a test with 2.10.0 snapshot and the search always shows "Any" - it does
not show the other options.
I noticed that in searchform_advanced.xsl the status dropdown list is shown
as
<xsl:for-each select="/root/gui/status/record">
When I think it should be
<xsl:for-each select="/root/gui/status/statusvalues/status">
If I fix this then the status will show up in the drop down list but it
does not seem to get filtered in the search results.
View this message in context: http://osgeo-org.1560.x6.nabble.com/metadata-status-question-tp5060177.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Ian,
as far as I can see, it was introduced in https://github.com/geonetwork/core-geonetwork/commit/eaf440f4589bb2622a17fc267ecd4b86d0c1858a and has since always been
<xsl:for-each select=“/root/gui/status/record”>
So maybe another change elsewhere is causing this behaviour ?
Kind regards
Heikki Doeleman
did a test with 2.10.0 snapshot and the search always shows “Any” - it does
as
<xsl:for-each select=“/root/gui/status/statusvalues/status”>
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
GeoNetwork-devel mailing list
This bug was fixed in 2.8
See Issue 139 <https://github.com/geonetwork/core-geonetwork/issues/139>
for more details.
View this message in context: http://osgeo-org.1560.x6.nabble.com/metadata-status-question-tp5060177p5062789.html
