Hello,
Can anyone tell me what is the use of column ‘title’ in table ‘metadata’?
It remains empty even though the metadata has a title and the only way I see to set it is via a hidden input field in metadata-insert-form.xsl.
Txs.
Hello,
Txs.
It has been around for as long as I've known (presumably it held metadata title at some stage..) but it is definitely in use for subtemplates - these are fragments of metadata from a schema and the title is used to identify them when they are displayed in the Administration->Manage Directories interface (for managing directories of subtemplates eg contact info or register items).
Simon
________________________________________
From: Mathieu Villemont [MATHIEU.VILLEMONT@anonymised.com]
Sent: Friday, 22 June 2012 6:52 PM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Metadata 'title' column
Hello,
Can anyone tell me what is the use of column 'title' in table 'metadata'?
Txs.
I see… so there is no way to get the metadata title other then parsing the XML or doing a Lucene query?
Mathieu
On 22 June 2012 11:09, <Simon.Pigot@anonymised.com> wrote:
It has been around for as long as I’ve known (presumably it held metadata title at some stage…) but it is definitely in use for subtemplates - these are fragments of metadata from a schema and the title is used to identify them when they are displayed in the Administration->Manage Directories interface (for managing directories of subtemplates eg contact info or register items).
Simon
Subject: [GeoNetwork-devel] Metadata ‘title’ columnHello,
It remains empty even though the metadata has a title and the only way I see to set it is via a hidden input field in metadata-insert-form.xsl.Txs.
hi Mathieu,
yes, that’s correct.
Kind regards
Heikki Doeleman
On Fri, Jun 22, 2012 at 11:14 AM, Mathieu Villemont <MATHIEU.VILLEMONT@anonymised.com> wrote:
Simon
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
