Jose,
This would be ideal for my users, who are already commenting on the
issue exactly as per 281.
Justin.
From: jose garcia [mailto:josegar74@anonymised.com]
Sent: 23 September 2010 17:04
To: jonathanmoules@anonymised.com
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Metadata title
Hi Jonathan
For me the best solution (not for 2.6.0 as should be released early) is:
1) When creating a template in the metadata editor and click to save it,
GeoNetwork should ask to the user for a title for the template
(independent of metadata title field). This title should be stored in
the database (not as part of metadata xml) and be used to display the
templates list titles when creating a new metadata.
When creating a new metadata from a template, should work as actual
showing the default values for the fields filled in the template. But as
the template title is managed independent as metadata title field, the
user can leave empty the last one.
2) Same when importing a template from xml file, GeoNetwork should ask
for a title for the template.
3) Add a form to maintain template titles (maybe in actual form to
reorder templates changing a bit to allow edit the titles also)
Not sure if more places need changes.
Jose Garcia
On Thu, Sep 23, 2010 at 5:34 PM, <jonathanmoules@anonymised.com>
wrote:
Hi Folks,
Further to my ticket http://trac.osgeo.org/geonetwork/ticket/281
and the comment at the end suggesting I raise the issue here on the dev
list - I think from a user-perspective that the "title" attribute should
be blank. At present it's populated with the title of the template that
it was created from. Personally I just think its bad UI to have it
pre-populated from the template.
(Note - I appreciate that metadata and templates are treated as being
essentially the same by GeoNetwork, but think some special exceptions
should be made, such as this).
Does anyone else have any thoughts/feelings on this?
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it,
or disclose it to anyone else. If you have received this transmission in
error please notify the sender immediately. All email traffic sent to or
from us, including without limitation all GCSX traffic, may be subject
to recording and/or monitoring in accordance with relevant legislation.
Nokia and AT&T present the 2010 Calling All Innovators-North America
contest
Create new apps & games for the Nokia N8 for consumers in U.S. and
Canada
$10 million total in prizes - $4M cash, 500 devices, nearly $6M in
marketing
Develop with Nokia Qt SDK, Web Runtime, or Java and Publish to Ovi Store
http://p.sf.net/sfu/nokia-dev2dev
GeoNetwork-devel mailing list
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
