[GeoNetwork-devel] metadata view and edit in tabs based UI?
I am trying to add a new view (similar to the default view but differing in elements) to the new tabs-based UI in GN 2.10.1 (tabsearch in apps). I know how to do it for the default gui (main.home). But not able to find their equivalent in tab-based ui.
from reading docs, it looks like the new tab-based UI does not use XSL, instead directly uses EXT widgets to show metadata but I’m not sure.
While I have started my own project source exploration, it will help and save me a few days if anyone can tell me a few points
  1. For creating new views (like inspire view) in tab-based ui, do I need to do it entirely in javascript?
  2. if XSLs are used in tab-based ui (for showing metadata) , where can I locate them?
  3. Do the same XSLs apply for metadata editing too?
Thanks and Regards
Ameet
