[GeoNetwork-devel] metadata visible problem
We have a GeoNetwork 2.0.3 running over Windows 2000 and we have installed
Oracle Express and MySQL to make some tests
We imported the metadata with the batch method and we would want to make
them visible to the Intranet and All groups, we executed some queries * to
add the records in the operationallowed table but even when the privileges
are checked the metadata still cant be viewed
Do I need to make another change beside adding the records?
Thanks in advance
Iván Israel
INSERT INTO OPERATIONALLOWED ( METADATAID, GROUPID, OPERATIONID )
SELECT ID, 1, 0 FROM METADATA WHERE ID NOT IN
(SELECT METADATAID FROM OPERATIONALLOWED WHERE GROUPID=1 AND OPERATIONID=0);
SELECT ID, 0, 0 FROM METADATA WHERE ID NOT IN
(SELECT METADATAID FROM OPERATIONALLOWED WHERE GROUPID=0 AND OPERATIONID=0);
Saludos…
Hi Ivan,
You'll have to stop the server and remove the Lucene index files. These have to be rebuild (this will happen on restart of the server) in order for the server to take them into account. The Lucene indexes are located in ../web/WEB-INF/lucene/
Ciao,
Jeroen
Thanks in advance
Iván Israel
Saludos....
opinions on IT & business topics through brief surveys-and earn cash
GeoNetwork-devel mailing list
I´ve got a question related to an exception rised when using dct:spatial.
(I´ve also tried BBOX with no luck). I was wondering if anyone could bring
any light into this as I am quite new in spatial queries and csw and I might
be stuck in something not supported or a bug. Thanks in advance.
Query:
<GetRecords service="CSW" version="2.0.1"
  xmlns="http://www.opengis.net/cat/csw&quot;
  xmlns:csw="http://www.opengis.net/cat/csw&quot;
  xmlns:ogc="http://www.opengis.net/ogc&quot;
  xmlns:gml="http://www.opengis.net/gml&quot; startPosition='1'
  maxRecords='10' resultType="results">
  <Query>
    <ElementSetName>summary</ElementSetName>
    <Constraint version='1.1.0'>
      <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot;&gt;
        <ogc:And>
          <ogc:PropertyIsLike wildCard="*"
singleChar="?"
            escape="\">
<ogc:PropertyName>dc:title</ogc:PropertyName>
<ogc:Literal>*polar*</ogc:Literal>
          </ogc:PropertyIsLike>
          <dct:spatial
xmlns:dct="http://purl.org/dc/terms/&quot;&gt;
            northlimit=41.256215
southlimit=38.154466
            eastlimit=-1.085282
westlimit=-5.372859
          </dct:spatial>
        </ogc:And>
      </ogc:Filter>
    </Constraint>
  </Query>
</GetRecords>
Exception rised:
<ows:ExceptionReport version='1.0.0' xmlns:ows='http://www.opengis.net/ows’>
<ows:Exception exceptionCode='NoApplicableCode'>
<ows:ExceptionText>Rised exception while searching metadata :
java.lang.IndexOutOfBoundsException: Index: 0 Size: 0</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Walter Barbera.
Hi Walter,
the dct:spatial property is a string and is not intended to be queried that way.
You need to query a bbox and the format is this:
<BBOX>
    <PropertyName>ows:BoundingBox</PropertyName>
    <gml:Envelope srsName="http://www.opengis.net/gml/srs/epsg.xml#63266405&quot;&gt;
      <gml:lowerCorner>100 100</gml:lowerCorner>
      <gml:upperCorner>200 200</gml:upperCorner>
    </gml:Envelope>
</BBOX>
Query:
  <Query>
        <ogc:And>
singleChar="?"
            escape="\">
          <dct:spatial
            eastlimit=-1.085282
westlimit=-5.372859
          </dct:spatial>
        </ogc:And>
      </ogc:Filter>
    </Constraint>
  </Query>
</GetRecords>
Exception rised:
</ows:Exception>
Walter Barbera.
Thanks for your quick response. I've got a similar problem related to dates
and probably is due to the same mistake as dct:spatial (I am having
difficulties to know when to use string/non-string properties and how). I'm
using dct:modified to query data within date intervals and I get the same
exception error (java.lang.IndexOutOfBoundsException: Index: 0 Size: 0).
      <ogc:PropertyIsGeaterThan>
<ogc:PropertyName>dct:modified</ogc:PropertyName>
        <ogc:Literal>2004-03-26</ogc:Literal>
      </ogc:PropertyIsGeaterThan>
Any idea? Thanks in advance,
Walter.
-----Mensaje original-----
De: geonetwork-devel-bounces@lists.sourceforge.net
[mailto:geonetwork-devel-bounces@lists.sourceforge.net] En nombre de Andrea
Carboni
Enviado el: jueves, 01 de marzo de 2007 12:31
Para: geonetwork-devel@lists.sourceforge.net
Asunto: Re: [GeoNetwork-devel] dct:spatial coordinates query problem
Hi Walter,
way.
<BBOX>
    <gml:Envelope
    </gml:Envelope>
</BBOX>
bring
might
Query:
  <Query>
        <ogc:And>
singleChar="?"
            escape="\">
          <dct:spatial
            eastlimit=-1.085282
westlimit=-5.372859
          </dct:spatial>
        </ogc:And>
      </ogc:Filter>
    </Constraint>
  </Query>
</GetRecords>
Exception rised:
</ows:Exception>
Walter Barbera.
your
Hi Walter,
I got a different error on Crisalis (the reference implementation for now):
Error during Filter to Lucene conversion : java.lang.IllegalStateException: Root element not set
This is due to the wrong element: PropertyIsGeaterThan -> PropertyIsGreaterThan
(i.e. a 'r' is missing). After this change, the query should work.
Walter.
Carboni
Hi Walter,
way.
<BBOX>
    <gml:Envelope
    </gml:Envelope>
</BBOX>
> Hi,
bring
might
> Query:
> <Query>
> <ogc:And>
> singleChar="?"
> escape="\">
> <dct:spatial
> eastlimit=-1.085282
> westlimit=-5.372859
> </dct:spatial>
> </ogc:And>
> </ogc:Filter>
> </Constraint>
> </Query>
> </GetRecords>
> Exception rised:
> </ows:Exception>
> Walter Barbera.
your
Hi Jeroen,
It works fine and have saved us a lot of time
Thanks
Ivan Israel
From: Jeroen Ticheler <Jeroen.Ticheler@anonymised.com>
To: Khrizart <khrizart@anonymised.com>
CC: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] metadata visible problem
Date: Wed, 28 Feb:40:57 +0100
Hi Ivan,
Ciao,
Jeroen
> installed
> make
> queries * to
> privileges
> Thanks in advance
> Iván Israel
> OPERATIONID=0);
> OPERATIONID=0);
> Saludos....
> share your
> projects/geonetwork
_________________________________________________________________
Express yourself instantly with MSN Messenger! Download today it's FREE! http://messenger.msn.click-url.com/go/onm00200471ave/direct/01/
