[GeoNetwork-devel] MetadataImport Proposal
Hi list,
I would like to know your opinion on new developments on metadata import.
This proposal improve XML metadata insert module.
I wrote a proposal here :
http://trac.osgeo.org/geonetwork/wiki/MetadataImport
You could also find a simple patch attached for review.
It could be proposed for vote ?
Mathieu Coudert
mcoudert@anonymised.com
Hi list,
coming back on this tutorial!
I updated the wiki page to add the possibility to choose an action inserting metadata (ie overwrite metadata with same UUID, generate UUID, no actions…). [1]
I also updated patch attached and screen shot.
Is there any objection on that ?
Could we process to a vote to add this into release 2.3 ??
Mathieu
[1] http://trac.osgeo.org/geonetwork/wiki/MetadataImport
On Mon, Oct 27, 2008 at 12:48 PM, Mathieu Coudert <mcoudert@anonymised.com> wrote:
Hi list,
Mathieu Coudert
Mathieu Coudert
Hi Mathieu,
Good work!
+1 for both of these from me.
One comment would be to ask if you can change the report on screen after the successful insert: could you display the link using the UUID instead of the internal id?
Ciao,
Jeroen
On Nov 13, 2008, at 11:15 AM, Mathieu Coudert wrote:
Hi list,
Mathieu
On Mon, Oct 27, 2008 at 12:48 PM, Mathieu Coudert <mcoudert@…31…> wrote:
Hi list,
Mathieu Coudert
Mathieu Coudert
This SF.Net email is sponsored by the Moblin Your Move Developer’s challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/_______________________________________________
GeoNetwork-devel mailing list
Jeroen Ticheler wrote:
Hi Mathieu,
Good work!
of the internal id?
Very nice addition. +1 from me on both, as well.
Archie
-- Archie Warnock warnock@anonymised.com
-- A/WWW Enterprises www.awcubed.com
-- As a matter of fact, I _do_ speak for my employer.
Hello Mathieu,
UUID, no actions...). [1]
+1 from me for selectionManager and new Import UI.
Ciao.Francois
Mathieu
wrote:
        Hi list,
        metadata import.
        Mathieu Coudert
Mathieu Coudert
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
_______________________________________________ GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geonetwork-devel GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
Francois Xavier Prunayre
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac Cedex
Tel : + 33 (0)6 34 11 71 75
http://www.camptocamp.com
francois-xavier.prunayre@anonymised.com
Thanks for your votes,
Glad to see that these proposals are welcomed!
I guess next step will be to commit it into trunk so my work ends here! :wink:
If you perform more tests, feedbacks are welcomed!
Mathieu
On Mon, Nov 17, 2008 at 11:55 PM, Francois-Xavier Prunayre <francois-xavier.prunayre@anonymised.com> wrote:
Hello Mathieu,
Ciao.Francois
Mathieu
wrote:
Hi list,
metadata import.
Mathieu Coudert
Mathieu Coudert
Mathieu Coudert
