Hello,
We are from the TU Delft university. We are working on LDAP integration of GeoNetwork.
In every documentation we find the option of LDAP authentication. In our settings we are not able to find this option. Is there something we are missing?
We use version 2.10.3.3 and also tried the newest version.
Thank you in advance,
Best regards, B. Bruens
On Mon, Jan 26, 2015 at 5:02 PM, Berjan Bruens <B.Bruens@anonymised.com> wrote:
Hello,
GeoNetwork.
missing?
As far as I know, version 2.10.x does not configure LDAP on the
settings but on xml files. Are you building from sources or using the
war provided? If it is the war, you have to explode (unzip) it, change
the files, and re-generate the war again.
María.
On 01/26/15 17:02, Berjan Bruens wrote:
Hello,
of GeoNetwork.
missing?
The configuration is spread amongst several files :
- you need to enable ldap auth in WEB-INF/config-security/config-security.xml (uncomment the config-security-ldap.xml import)
- then configure it for your setup in WEB-INF/config-security/config-security.properties
- and maybe have a look at WEB-INF/config-security/config-security-overrides.properties for ldap attributes/profile mapping
Landry Breuil
Mouton a 5 pattes du CRAIG
Hi
Probably the old settings to setup LDAP are still available in the UI, but not used. In 2.10.X should be used the files as pointed by Landry and Maria.
Jose García
On Mon, Jan 26, 2015 at 5:07 PM, Landry Breuil <breuil@anonymised.com> wrote:
Hello,
of GeoNetwork.
missing?
Landry Breuil
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
