[GeoNetwork-devel] Missing "Next" and "Previous" strings
Do a search that returns
more than 20 results, and click
on the "3" at the bottom of the
page to go to the third page of results.
If you look closely at the "1"
at the bottom of the page,
the underline of the link
extends to the left. If you
hover the mouse over it and slide
to the left and right,
you'll see that it's _two_ links.
The link on the left is in fact
a "previous" link with an empty label.
It seems that
both search-results.xml and
search-results-xhtml.xml refer to
/root/gui/strings/next and
/root/gui/strings/previous,
but there's no <next> or
<previous> in strings.xml.
It has been so ever since
revision 2 - ouch!
After adding definitions
of <next> and <previous> to
strings.xml, now I have
nice new Next and Previous
buttons on my search results pages!
Richard Walker
Software Improvements Pty Ltd
Phone: +61 2 6273 2055
Fax: +61 2 6273 2082
Hi Richard,
Indeed, I found that also recently and added the strings in my local source code. I should commit that fix soon.
Jeroen
It seems that
revision 2 - ouch!
Richard Walker
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
GeoNetwork-devel mailing list
