[GeoNetwork-devel] Missing update-srv-attachDataset
I see that in this commit (made by Francois, CC'ed)
    https://github.com/geonetwork/core-geonetwork/commit/edf83a
the file process/update-srv-attachDataset.xsl has been removed.
Anyway the process is still referred both in 2.10.x:
./web-
client/src/main/resources/apps/js/GeoNetwork/lib/GeoNetwork/widgets/editor/EditorPanel.js
./web/src/main/webapp/scripts/editor/metadata-editor.js
and in develop
./web-
It seems that most of the code (with functionalities extended a bit) was
ported into process/dataset-add.xsl.
Anyone working on this?
   Emanuele
Ing. Emanuele Tajariol
Technical Lead
Via Poggio alle Viti 1187
mob: +39 380 2116282
Hi Emanuele,
2014-11-05 12:01 GMT+01:00 Emanuele Tajariol <etj@anonymised.com>:
I see that in this commit (made by Francois, CC’ed)
./web-
and in develop
./web-
Maybe an error when working on the relation panel. For the Angular editor (in develop), only the dataset-add.xsl is used.
Do you have time to add the file back to at least 2.10.x ?
Cheers.
Francois
Emanuele
Technical Lead
Hi Francois,
Sure.
   Emanuele
Alle 12:18:40 di Wednesday 5 November 2014, Francois Prunayre ha scritto:
Hi Emanuele,
> Hi all,
> ./web-
> r/EditorPanel.js ./web/src/main/webapp/scripts/editor/metadata-editor.js
and in develop
> ./web-
> r/EditorPanel.js
Cheers.
Francois
> Cheers,
> Emanuele
Technical Lead
https://github.com/geonetwork/core-geonetwork/issues/671
Alle 12:57:51 di Wednesday 5 November 2014, Emanuele Tajariol ha scritto:
Hi Francois,
Sure.
   Emanuele
> Hi Emanuele,
> > Hi all,
> > ./web-
> > to r/EditorPanel.js
> and in develop
> > ./web-
> > to r/EditorPanel.js
> > was ported into process/dataset-add.xsl.
> Cheers.
> Francois
> > Cheers,
> > Emanuele
Technical Lead
