[GeoNetwork-devel] More (better?) XSD validation errors and XSLT 2.0 support
I've been doing a bit of investigation into JAXP in GN with a view to getting XSLT 2.0 support and improvements to the XSD validation error messages - turns out that the current approach where Jeeves throws an exception on the first validation error returned from the JAXP validator class, loses additional messages that can help provide really useful context for some error messages. For example, leaving a gco:Distance element blank causes a fairly cryptic error to be returned by the current validator in GN/Jeeves:
org.xml.sax.SAXParseException: cvc-datatype-valid.1.2.1: '' is not a valid value for 'double'.
Not terribly helpful because it doesn't tell you which element has the invalid value. A fairly simple mod is to insert an error handler and collect all the errors and then throw an exception afterwards. With this in place the validation messages returned from the above become:
ERROR(1) org.xml.sax.SAXParseException: cvc-datatype-valid.1.2.1: '' is not a valid value for 'double'.
ERROR(2) org.xml.sax.SAXParseException: cvc-complex-type.2.2: Element 'gco:Distance' must have no element [children], and the value must be valid.
Ok - still a bit cryptic - but at least we can guess that the element that doesn't have a valid value is gco:Distance and that makes it a lot easier to find the problem area in the XML view. Possibly useful to is that we can also get more validation errors if there are other problems in the document, like this one which has a blank gco:Distance and also doesn't have a topicCategory code:
ERROR(3) org.xml.sax.SAXParseException: cvc-enumeration-valid: Value '' is not facet-valid with respect to enumeration '[farming, biota, boundaries, climatologyMeteorologyAtmosphere, economy, elevation, environment, geoscientificInformation, health, imageryBaseMapsEarthCover, intelligenceMilitary, inlandWaters, location, oceans, planningCadastre, society, structure, transportation, utilitiesCommunication]'. It must be a value from the enumeration.
ERROR(4) org.xml.sax.SAXParseException: cvc-type.3.1.3: The value '' of element 'gmd:MD_TopicCategoryCode' is not valid.
and to make things just a little bit nicer we could let the user select the number of validation messages they want to see as part of their session. Might speed up the process of fixing these problems a bit...
It's still a pretty cryptic interface but at least there is a bit more info to help with context and maybe it begins to open the door for connecting up these error messages with the XML/advanced editor views (It's a shame that these errors return line number and column number of -1 - more investigation required - but it might be related to the in memory source we're using....)
XSLT 2.0 support - we have a few quite large XSLT convertors being written (eg. for GCMD DIF to ISO 19115/19139) that we'd like to use in GN. The writers have chosen to use XSLT 2.0 and it does kind of work within GN now so long as the writers use xalan constructs, however it seems nice to have XSLT 2.0 support (I think?) and most of the converter writers seem to be using SAXON, so I've done a trial by switching over our GN 2.2 working copy to use SAXON in JAXP - GN and Intermap seem to work ok once you convert the xalan functions in a few of the xslts (easy) - but is this something people want? And, I'm sure someone has probably tried this before, so maybe there are reasons why we stick with xalan and XSLT 1.0?
Simon
Hi Simon,
Thanks for those suggestions that seem excellent!
I solicited feedback from Andrea on this and he said he also had this move in mind :slight_smile: He also suggested to not automatically convert the XSL files from XSLT1.0 to XSLT2.0 but do this stepwise.
My 0.1cent.
Ciao,
Jeroen
On Feb 23, 2008, at 5:53 PM, Simon Pigot wrote:
xalan and XSLT 1.0?
Simon
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-devel mailing list
