I have been out of the game for a little while now so forgive me if I miss the boat here but in addition to better error descriptions I think one of the main things that we could achieve would be to highlight on the UI the element that is incorrect. Could this not be achieved with the current software by working backwards from the line reference in the error, and writing that against the element?
---- John.Hockaday@anonymised.com wrote:
Hi Simon and all,
I have used Saxon9 to translate my XML documents very successfully. Michael
Kay is virtually the creator of XSLT and XSLT 2.0 He also writes Saxon so it
would seem to me that he would make sure that his software would meet the
XSLT 2.0 specification as best as he can.I have used other parsers like XMLSpy and found that they do not fully
implement the specifications of some XML standards. Hence where ever
possible I have gone to the software written by the specification writer.
IE. Michael Kay, James Clarke.I strongly support the use of Saxon as the validation tool. Also the more
that a user can use to find out where the errors occur in their metadata is
also more useful.My two cents worth.
Thanks.
John
> -----Original Message-----
> From: geonetwork-devel-bounces@lists.sourceforge.net
> [mailto:geonetwork-devel-bounces@lists.sourceforge.net] On
> Behalf Of Simon Pigot
> Sent: Sunday, 24 February 2008 3:54 AM
> To: geonetwork-devel@lists.sourceforge.net
> Cc: anzlicmet-l@anonymised.com
> Subject: [GeoNetwork-devel] More (better?) XSD validation
> errors and XSLT2.0 support
> Hi,
> I've been doing a bit of investigation into JAXP in GN with a view to
> getting XSLT 2.0 support and improvements to the XSD validation error
> messages - turns out that the current approach where Jeeves throws an
> exception on the first validation error returned from the
> JAXP validator
> class, loses additional messages that can help provide really useful
> context for some error messages. For example, leaving a gco:Distance
> element blank causes a fairly cryptic error to be returned by the
> current validator in GN/Jeeves:
> org.xml.sax.SAXParseException: cvc-datatype-valid.1.2.1: '' is not a
> valid value for 'double'.
> Not terribly helpful because it doesn't tell you which
> element has the
> invalid value. A fairly simple mod is to insert an error handler and
> collect all the errors and then throw an exception
> afterwards. With this
> in place the validation messages returned from the above become:
> ERROR(1) org.xml.sax.SAXParseException:
> not a valid value for 'double'.
> ERROR(2) org.xml.sax.SAXParseException: cvc-complex-type.2.2: Element
> 'gco:Distance' must have no element [children], and the value
> must be valid.
> Ok - still a bit cryptic - but at least we can guess that the element
> that doesn't have a valid value is gco:Distance and that
> makes it a lot
> easier to find the problem area in the XML view. Possibly
> useful to is
> that we can also get more validation errors if there are
> other problems
> in the document, like this one which has a blank gco:Distance
> and also
> doesn't have a topicCategory code:
> must be valid.
> ERROR(3) org.xml.sax.SAXParseException:
> cvc-enumeration-valid: Value ''
> is not facet-valid with respect to enumeration '[farming, biota,
> boundaries, climatologyMeteorologyAtmosphere, economy, elevation,
> environment, geoscientificInformation, health,
> imageryBaseMapsEarthCover, intelligenceMilitary,
> inlandWaters, location,
> oceans, planningCadastre, society, structure, transportation,
> utilitiesCommunication]'. It must be a value from the enumeration.
> ERROR(4) org.xml.sax.SAXParseException: cvc-type.3.1.3: The
> value '' of
> element 'gmd:MD_TopicCategoryCode' is not valid.
> and to make things just a little bit nicer we could let the
> user select
> the number of validation messages they want to see as part of their
> session. Might speed up the process of fixing these problems a bit...
> It's still a pretty cryptic interface but at least there is a
> bit more
> info to help with context and maybe it begins to open the door for
> connecting up these error messages with the XML/advanced editor views
> (It's a shame that these errors return line number and column
> number of
> -1 - more investigation required - but it might be related to the in
> memory source we're using....)
> XSLT 2.0 support - we have a few quite large XSLT convertors being
> written (eg. for GCMD DIF to ISO 19115/19139) that we'd like
> to use in
> GN. The writers have chosen to use XSLT 2.0 and it does kind of work
> within GN now so long as the writers use xalan constructs, however it
> seems nice to have XSLT 2.0 support (I think?) and most of
> the converter
> writers seem to be using SAXON, so I've done a trial by
> switching over
> our GN 2.2 working copy to use SAXON in JAXP - GN and
> Intermap seem to
> work ok once you convert the xalan functions in a few of the xslts
> (easy) - but is this something people want? And, I'm sure someone has
> probably tried this before, so maybe there are reasons why we
> stick with
> xalan and XSLT 1.0?
> Cheers,
> Simon
> This SF.net email is sponsored by: Microsoft
> Defy all challenges. Microsoft(R) Visual Studio 2008.
> http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> GeoNetwork-devel mailing list
> GeoNetwork-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
> GeoNetwork OpenSource is maintained at
> http://sourceforge.net/projects/geonetwork
