I have duplicated the geonetwork harvester to add multinode support. But before merging, I want to ask for your opinion. Should we have a harvester prepared for geonetwork 2.9+ and a different harvester for 3.0+ or should we merge both in the same type of harvester?
The current differences between them are just adding a “node” field to support multinode harvesting, but from a conceptual point of view I am not sure if a user will understand better how to use both harvesters if they are two different types.
https://github.com/geonetwork/core-geonetwork/pull/674
Also, this depends if we are going to add more differences, which I think not.
María.
Hi Maria
If depends on the version of GeoNetwork to harvest I think we can use xml.info service to get this information and display the node field depending on this information, having all in 1 harvester, if no more changes are there.
Having one harvester, would be less confusing.
How old versions manage to harvest from multinode in develop branch, if using only 1 node?
Jose García
On Tue, Nov 11, 2014 at 8:39 AM, María Arias de Reyna <delawen@anonymised.com> wrote:
María.
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://pubads.g.doubleclick.net/gampad/clk?id=154624111&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
On Tue, Nov 11, 2014 at 8:51 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Maria
changes are there.
Ok. Then you think that the field "node" should be hidden until the user
writes the url of geonetwork and then it gets the version on an ajax call?
Do we already have a service that returns a list of nodes? Would it be a
good idea or a security breach? Right now, I left the "node" field as a
free-text value.
using only 1 node?
That's why I made this change. If you have more than one node, or your node
is not called "srv", you cannot harvest to multinode.
Jose García
On Tue, Nov 11, 2014 at 8:39 AM, María Arias de Reyna <delawen@anonymised.com...>
wrote:
The current differences between them are just adding a "node" field to
not.
María.
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
<http://geocat.net/> for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 136721 WD BennekomThe
Netherlandshttp://GeoCat.net/>*
