Does anyone use multiple datasources in their geonetwork instance ?
In the code, i see that the DataSource bean (for the main db) is wired with the getBean(DataSource.class) command, what fails if you declare multiple datasources.
If nobody did this already, i will submit a PR changing the bean wiring from class type to bean id.
camptocamp
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
Never used several data sources, for custom projects I usually create the tables in the GeoNetwork database. In any case, looks a good change to wire by identifier.
camptocamp
Florent Gravin
0479444492
Go from Idea to Many App Stores Faster with Intel(R) XDK
Give your users amazing mobile app experiences with Intel(R) XDK.
Use one codebase in this all-in-one HTML5 development environment.
Design, debug & build mobile apps & 2D/3D high-impact games for multiple OSs. http://pubads.g.doubleclick.net/gampad/clk?id=254741551&iu=/4140
