[GeoNetwork-devel] Multiple Instances of GeoNetwork?
Hi Michelle,
The conflicts you can have are:
1- same servlet name
2- same servlet port
3- same Z39.50 port
4- same dbms port
Using Tomcat, (1) and (2) are automatically avoided. If you use a dbms other
than the embedded one, (4) should be avoided too. If not, you have to change
both the WEB-INF/db/db.conf (use a port other than 9157, like 9158) and the
config.xml (the resource part, specifying the new port).
(3) can be easily changed editing the config.xml file (app handler section).
If you are using GN 2.1 beta1, you can use GAST for (1), (2) and (4) and the
online config page for (3).
If you still have problems, please send me the log files of the 2 instances.
Jeroen, Andrea:
We have searched the GeoNetwork forums and even submitted this question
but have heard no answer. Am hoping you can help us out ...
We are trying to run 2 instances of GeoNetwork on our Linux server. One
instance will run as a portal for South America and the second instance
will replace our old Blue Angel Z39.50 gateway.
Our 2 instances seem to have conflicts with each other with the database
and the searching components.
Is it possible to run multiple instances, each in their own
tomcat/webapps/ folder and each with their own database, without
conflicts? Is there anything special that we must do?
Thanks
Michelle
Michelle Anthony
FGDC and International Projects - Software Engineering Project Lead
Technical Support Services Contractor
For the National Center for Earth Resources Observation and Science (EROS)
Sioux Falls, SD 57198
605.594.6848
605.594.6940
anthony@anonymised.com
Andrea Carboni <acarboni@anonymised.com>
11/02/2006 08:50 AM
Please respond to
To
Michelle L Anthony <anthony@anonymised.com>
cc
Jeroen Ticheler <Jeroen.Ticheler@anonymised.com>, Stefano Giaccio
<sgiaccio@anonymised.com>
Subject
Re: GeoNetwork 2.0.3 and InterMap Issue?
Hi Michelle,
I don't know what is going on with intermap. I copied Stefano, the
'intermap man'
to provide some light into it.
> Hi Andrea:
> I am trying to use GeoNetwork to put together a demo for GSDI in Chile
> next week.
> We have installed version 2.0.3 today on our server and everything seems
> to be operating correctly except InterMap will not display any images.
> Here is the URL:
> http://edclxs25.cr.usgs.gov/geonetwork/srv/en/main.home
> Do you have any ideas why this might happen?
> Thanks
> Michelle
> Michelle Anthony
(EROS)
> 605.594.6848
> 605.594.6940
