[GeoNetwork-devel] New "how to" index on Trac
I added a new index of "how to" documents
on the Trac site - there's a link to it
on the front page. This index automatically
lists all pages that have a name
beginning with "HowTo".
I created two "how to" documents:
1. Building GN without using the installer.
2. Running GN under Tomcat.
Richard Walker
Software Improvements Pty Ltd
Phone: +61 2 6273 2055
Fax: +61 2 6273 2082
Nice touch and good idea, although it might be wise to run the idea past Jeroen and make sure we fit in with his master documentation plan.
Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Commercial Support for Geospatial Open Source Solutions
http://www.lisasoft.com/LISAsoft/SupportedProducts.html
Hi Richard and Cameron,
Thanks! I think this is a much needed improvement that I didn't get to and I probably lack the organized mindset for :slight_smile: Seeing more people than just myself and a few others update content and (re-)organize is just great!
Jeroen
Cameron Shorter
Check out the new SourceForge.net Marketplace.
It's the best place to buy or sell services for
just about anything Open Source.
http://sourceforge.net/services/buy/index.php
GeoNetwork-devel mailing list
Hi All,
I've started working with GeoNetwork recently and could have used that HowTo last week, and I ended up setting up GN on tomcat slightly differently ( by using a context file in conf/Catalina/localhost) which I will add to the wiki as an alternative .
I did run into another problems that could use a HowTo:
- initialization of McKoi DB passwords: trying various things kept resulting in a McKoi "db.conf file not found error" even though the file was there. I got it to work by copying the WEB-INF/config.xml file from GN installed by the installer into the tomcat instance and it worked. Is there info on that anywhere?
Mike Adair
DM Solutions Group
Jeroen
Cameron Shorter
Um, that's a bit too vague; you'll have to be more explicit
about what you did. In particular, if you had copied the
subdirectories of the web directory into your Tomcat webapps
directory -- as per the "how to" -- you would certainly
have the two WEB-INF/config.xml files in the right places.
Richard Walker
Hi Mike!
I _think_ this is because the db.conf file that the installer generated contains the proper username and password for the McKoi Db you were trying to use. The DB is created and filled during the installation process and a username and password are then generated. A fresh SVN copy thus has no DB ready to go.
Ciao,
Jeroen
Richard Walker
Hi Mike!
The "how to" for compiling GN already includes
a step to run GAST to initialize the database;
for good measure, I have now added an explicit reminder
to do that to the Tomcat "how to".
Richard Walker
Indeed it looks like running GAST to init the DB is the step I was missing. It appears that both the installer and GAST are used to set the McKoi DB passwords. In any case I have it working with Postgres now but that is still useful to know.
And yes I omitted that the intermap application also needs an equivalent context XML document to set up for tomcat in the way I described (geoserver too if needed). Sorry about that but I see that's already been added to the wiki. On a windows system, having spaces in the path name for docBase works fine with this method.
Mike
Hi Mike!
One thing I haven't found yet is how to get a list of all the metadata records owned by a particular user, or that belong to a certain group. Does such a page exist in GN?
Mike
Hi Mike,
You can filter on groups, but not on a user indeed. Actually I think there's a problem even with the filtering on groups at the moment (not sure I'm right here).
Ciao,
Jeroen
Mike
Yep - there was a problem there - I have a fix for that in the BlueNet stuff I need to apply.
Simon
-----Original Message-----
From: geonetwork-devel-bounces@lists.sourceforge.net on behalf of Jeroen Ticheler
Sent: Fri 6/13/2008 1:03 AM
To: Mike Adair
Cc: geonetwork-devel@lists.sourceforge.net Devel
Subject: Re: [GeoNetwork-devel] list of records owned by user
Hi Mike,
Ciao,
Jeroen
Mike
geonetwork-devel List Signup and Options
