Hi Francois
I followed anyway your suggestion about the template and added this to my schema layout.xsl, but the template seem not used, the message is not displayed in the console and the values are the old ones still:
<xsl:variable name=“iso19139naplioschema” select=“/root/gui/schemas/iso19139.naplio”/>
<xsl:variable name=“iso19139napliocodelists” select=“$iso19139naplioschema/codelists”/>
<xsl:template mode=“mode-iso19139” priority=“300” match=“gmd:CI_RoleCode”>
<xsl:param name=“schema” select=“$schema” required=“no”/>
<xsl:param name=“labels” select=“$labels” required=“no”/>
<xsl:param name=“codelists” select=“$iso19139napliocodelists” required=“no”/>
<xsl:variable name=“xpath” select=“gn-fn-metadata:getXPath(.)”/>
<xsl:variable name=“isoType” select=“if (…/@gco:isoType) then …/@gco:isoType else ‘’”/>
xsl:messageHERE WE ARE =======================================================</xsl:message>
// CURRENT CODE …
<xsl:with-param name=“listOfValues”
select=“gn-fn-metadata:getCodeListValues(‘iso19139.naplio’, name(*[@codeListValue]), $codelists, .)”/>
</xsl:call-template>
</xsl:template>
Maybe is good to plan in IRC a brief session about the architecture of the new metadata editor components, at least to have a general idea to get productive on developments. Let me know what do you think about this.
Jose García
On Fri, Mar 14, 2014 at 10:06 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi
Sorry, just checking a bit more the code, seem this can be the problem. In https://github.com/geonetwork/core-geonetwork/blob/develop/web-ui/src/main/resources/catalog/components/edit/directoryentryselector/DirectoryEntrySelector.js#L124:
// TODO: Schema should be a parameter
gnSchemaManagerService
.getCodelist(‘iso19139|gmd:CI_RoleCode’)
Jose García
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
On Fri, Mar 14, 2014 at 10:03 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Francois
I see that is invoked the md.element.info to get the codelist values, but it sends the schema to iso19139. In SchemaManagerService:
var info = config.split(‘|’),
requestBody = ‘<codelist schema="’ + info[0] +
For some reason the schema is identified wrongly, but not sure yet from where comes config stuff, trying to get into the details of the developments.
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
On Fri, Mar 14, 2014 at 9:58 AM, Francois Prunayre <fx.prunayre@anonymised.com> wrote:
Hi Jose,
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
2014-03-13 15:55 GMT+01:00 Jose Garcia <jose.garcia@anonymised.com>:
Hi
In working in a new metadata profile based on iso19139 where I have customised some of the codelists.
In the “classic” metadata editor are displayed properly the new values for the codelist fields, but in the trunk new metadata editor are displayed the codelist values from iso19139.
In my metadata profile I added similar files to these https://github.com/geonetwork/schema-plugins/tree/master/iso19139.fra/layout to get it working in the new metadata editor.
Not sure if it’s a bug in the new metadata editor or I’m missing some configuration?
You probably have 2 options:
override the codelist template to do something specific for your schema
https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/WEB-INF/data/config/schema_plugins/iso19139/layout/layout.xsl#L262
modify the getCodeListValues function.
Francois
Jose García
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Learn Graph Databases - Download FREE O’Reilly Book
“Graph Databases” is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/13534_NeoTech
GeoNetwork-devel mailing list
