Hi Francois,
Thanks for the reply. I already tried that but it wouldn't remove it and it still appeared whenever I create or edit a template. I wanted to know that which files actually refer to the interface?
Have you got any idea.
Regards
Faizan
From: François Prunayre [mailto:fx.prunayre@anonymised.com]
Sent: 19 January 2007 08:07
To: Faizan Tayyab
Cc: geonetwork-devel@lists.sourceforge.net
Subject: RE: [GeoNetwork-devel] (no subject)
Hi Faizan, if your new schema is based on ISO19115, you could just create a template using the interface with the fields you want to have in.
For example, default template have the CharSetCd element.
XML View for the template is "</mdLang>
<mdChar> <CharSetCd value="utf8"/> </mdChar>
<mdContact>"
You could remove the CharSetCd from the interface and save the updated template that editor will use later ....
XML View for the template is now "</mdLang>
<mdContact>"
HTH.
Francois
De : geonetwork-devel-bounces@lists.sourceforge.net [mailto:geonetwork-devel-bounces@lists.sourceforge.net] De la part de Faizan Tayyab
Envoyé : jeudi 18 janvier 2007 15:27
À : Jeroen Ticheler
Cc : geonetwork-devel@lists.sourceforge.net
Objet : Re: [GeoNetwork-devel] (no subject)
Although I have been trying to follow the steps but it is still very complex and confusing. Can you let me know that if I want to remove a field from ISO standard, what needs to be done? Such that when a new metadata is created, that field is simply removed from the template.
For example if I want to remove CharSetCd,
I have tried removing it from various files but it still shows up as an element whenever I want to create a new metadata.
Regards
Faizan
From: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Sent: 18 January 2007 11:24
To: Faizan Tayyab
Subject: Re: [GeoNetwork-devel] (no subject)
Hi Faizan,
Adding a new standard is not a two minutes thing
However, I suggest you browse through the mailing list archives because this has been discussed a number of times and the steps to take have been explained in emails on this list. If after reading through those you still find yourself in trouble, you can post specific questions to the list again.
Hope this helps,
Ciao,
Jeroen
On Jan 18, 2007, at 12:08 PM, Faizan Tayyab wrote:
Hi Jeroen,
I want to include UK Gemini as a standard. At the moment I have FGDC, DUBLIN CORE, AND ISO... To me the number of files make the thing quite complex. How can a new standard be added.
The dropdown I am talking about contains the name of templates on the metadata creation page. How do I include UK Gemini as an element. Which file is the referring to the interface of that page containing the code for the drop down.
Regards
Faizan
From: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com ]
Sent: 18 January 2007 11:04
To: Faizan Tayyab
Cc: geonetwork-devel@lists.sourceforge.net <mailto:geonetwork-devel@anonymised.comourceforge.net>
Hi Faizan,
Thanks for your email.
Could you be a little bit more specific on what you are trying to achieve? Do you want to add something to an existing dropdown box or a completely new dropdown box?
Ciao,
Jeroen
On Jan 18, 2007, at 11:57 AM, Faizan Tayyab wrote:
Does anybody know which files refer to the interface itself. I want to include an option in a drop down box on the metadata creation page.
Faizan Tayyab
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
opinions on IT & business topics through brief surveys - and earn cash
GeoNetwork-devel mailing list
GeoNetwork-devel@lists.sourceforge.net <mailto:GeoNetwork-devel@anonymised.comeforge.net>
Ordnance Survey
Romsey Road
Tel: 08456 050505
<mime-attachment.txt>
Ce message a ete verifie par MailScanner <http://www.mailscanner.info/> pour des virus ou des polluriels et rien de suspect n'a ete trouve.
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et privis.Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Any data and information contained in this electronic mail is personal, confidential and private. Any total or partial publication, use or distribution must be authorized.
Ordnance Survey
Romsey Road
Tel: 08456 050505
Les donnees et renseignements contenus dans ce message sont personnels, confidentiels et privés.Toute publication, utilisation ou diffusion, meme partielle, doit etre autorisee.
Ordnance Survey
Romsey Road
Tel: 08456 050505
