[GeoNetwork-devel] Not fixed - please reopen #232: Map coords & boxes drawn in wrong position when page scrolled
Could someone please reopen #232<https://github.com/geonetwork/core-geonetwork/issues/232&gt;?
Or should I raise another issue?
Actually François's fix was not complete. Testing the Advanced Search map in apps/tabsearch/index.html:
1. If you scroll the page, then draw a box with the Select tool, it's OK, and if you zoom then, that's ok too.
2. But if you scroll the page, then zoom, the box is still in the wrong place.
3. Also if you scroll the page and check the map coordinates displayed in the bottom right corner, the latitude is wrong.
Jonathan Doig
Senior Data Program Coordinator
Information Sciences Branch
NSW Office of Environment and Heritage
PO Box 1967, Hurstville NSW 1481
Ph: 02 9585 6372 Mobile: 0409 049185
This email is intended for the addressee(s) named and may contain confidential and/or privileged information.
If you are not the intended recipient, please notify the sender and then delete it immediately.
Any views expressed in this email are those of the individual sender except where the sender expressly and with authority states them to be the views of the Office of Environment and Heritage, NSW Department of Premier and Cabinet.
PLEASE CONSIDER THE ENVIRONMENT BEFORE PRINTING THIS EMAIL
