[GeoNetwork-devel] Not Listing all Packages
HI,
While installing the GeoNetwork in my machine it is not listing all the packages, listing only Core package, please let me know where is the problem, is there any other configuration required to do the installation successfully.
Praveen.
Praveen,
What packages are you referring to? Just follow the wizard , all the modules will be installed and the application will run on Jetty server with mckoi db.
Regards
Kumaran
From: Praveenkumar Anugandula [mailto:Praveenkumar.Anugandula@anonymised.com]
Sent: Friday, May 20, 2011 3:36 PM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Not Listing all Packages
HI,
Praveen.
DISCLAIMER:
This email may contain confidential information and is intended only for the use of the specific individual(s) to which it is addressed. If you are not the intended recipient of this email, you are hereby notified that any unauthorized use, dissemination or copying of this email or the information contained in it or attached to it is strictly prohibited. If you received this message in error, please immediately notify the sender at Infotech or Mail.Admin@anonymised.com and delete the original message.
in earlier versions there were more packages listed than just ‘core’, some of which were optional. But that’s not now the case. Don’t worry about it, just install.
Kind regards
Heikki Doeleman
On Fri, May 20, 2011 at 3:50 PM, Kumaran Narayanaswamy <kumaran.narayanaswamy@anonymised.com> wrote:
Praveen,
Regards
Kumaran
To: geonetwork-devel@anonymised.comists.sourceforge.net
HI,
Praveen.
DISCLAIMER:
What Every C/C++ and Fortran developer Should Know!
Read this article and learn how Intel has extended the reach of its
next-generation tools to help Windows* and Linux* C/C++ and Fortran
developers boost performance applications - including clusters.
http://p.sf.net/sfu/intel-dev2devmay
GeoNetwork-devel mailing list
