I notice the following is listed as a note/issue in the GeoNetwork
documentation:
"Every time the harvester runs, it will remove previously harvested
information and create new ones. GeoNetwork will generate the id for all
metadata (both service and datasets). Therefor, for datasets, if the
metadata is created using a remote XML document (ie. if a MetadataUrl tag is
in the GetCapability document), the UUID of the document is used."
Is there a plan to fix this (ie: update records on harvest rather than
create new ones) or has it already been fixed in some version of GN?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/OGC-service-harvesting-type-issue-tp5680860p5680860.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
