I just downloaded GN2.10RC2 to test and discovered that I could not access
the OGC Web Services Harvesting interface. All the other harvesting
interfaces I tried seemed fine. It gave a javascript Null type error in
gn.libs.js line 1038. No visible errors in the jetty logs. Using a Firefox
browser. Both service and client on the same Ubuntu 12.04 install using
default installation.
Could not access Trac to submit bug as it seems to be down.
Byron
View this message in context: http://osgeo-org.1560.x6.nabble.com/OGC-Web-Services-Harvesting-interface-error-tp5054866.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Byron,
could you check that cleaning your browser cache does not help solving
the issue ?
are you migrating or running a clean install ?
Cheers.
Francois
2013/5/22 ByronCinNZ <cochranes4@anonymised.com>:
Byron
Try New Relic Now & We'll Send You this Cool Shirt
New Relic is the only SaaS-based application performance monitoring service
that delivers powerful full stack analytics. Optimize and monitor your
browser, app, & servers with just a few lines of code. Try New Relic
and get this awesome Nerd Life shirt! http://p.sf.net/sfu/newrelic_d2d_may
GeoNetwork-devel mailing list
Yep. Clearing the console did it. I have a GN2.8 install on the same machine.
Should have done that as a matter of course.
Thanks, Francois.
View this message in context: http://osgeo-org.1560.x6.nabble.com/OGC-Web-Services-Harvesting-interface-error-tp5054866p5054874.html
On Wed, May 22, 2013 at 11:39 AM, ByronCinNZ <cochranes4@anonymised.com> wrote:
I have tried with a Debian using Firefox and it seems I get no error.
Does the harvest administration panel look different from 2.8? (It
shouldn't)
It's weird that other harvest interfaces work ok and this fails, as
this line you mention of gn.libs.js is a common line for all harvest
interfaces. Have you tried with a debug parameter? Like
http://localhost:8080/geonetwork/srv/eng/harvesting?debug=true Does it
fail then?
MarĂa.
Byron
