Hi GeoNetwork community,
I'm currently working on enabling an application to interact with GeoNetwork.
I found that GN was having trouble parsing the CQL expressions in my requests, so I went ahead and took a look.
I'm working on GeoNetwork trunk from svn.
What I found is that AbstractOperation.convertCQL(String):Element is using the GeoTool's old xml tech to encode the org.opengis.filter.Filter to an XML string. That is, org.geotools.filter.FilterTransformer instead of org.geotools.xml.Encoder. The rest of the code base seems to correctly being using org.geotools.xml.Parser (the Encoder counterpart).
Problem is FilterTransformer is old and I guess it works only with Filter 1.0., and it fails with an exception if trying to encode a PropertyIsLike filter.
Changing the code as in the following patch to use Encoder instead solves the problem: <http://pastebin.com/m2daef52f>, but with the catch of having to upgrade the geotools version used by GeoNetwork. Currently GN uses GeoTools 2.5.1, which ignored a PropertyIsLike filter producing an empty Filter xml string. Upgrading to the latest 2.5 release solves it.
Otherwise, I can't use any LIKE filter in a GetRecords request.
Would you please consider applying the above mentioned patch and upgrading to a newer GeoTools?
Gabriel
Gabriel Roldan
OpenGeo - http://opengeo.org
Hi Gabriel,
On Tue, Dec 15, 2009 at 9:05 PM, Gabriel Roldan <groldan@anonymised.com> wrote:
I’m currently working on enabling an application to interact with
GeoNetwork.
I’m working on GeoNetwork trunk from svn.
using the GeoTool’s old xml tech to encode the org.opengis.filter.Filter
Otherwise, I can’t use any LIKE filter in a GetRecords request.
+1 from my side.
We choose to start with GeoTools 2.5.1 at this time because it was one of the last GeoTools release.
I do not think there is any side effect upgrading Geotools to the 2.5.8 release.
I will have a look on that tomorrow and I will let you know about that.
Thanks for feedback and contribution,
Mathieu
Gabriel
Gabriel Roldan
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon’s best-in-class app development support
A streamlined, 14 day to market process makes app distribution fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
GeoNetwork-devel mailing list
Hola Gabriel,
I applied your patch to the trunk and upgraded geotools to release 2.5.8.
After tests, sounds good to me to move on.
I also created a ticket for that bug : http://trac.osgeo.org/geonetwork/ticket/178
If any objection among the community I will commit it soon.
Thanks again,
ciao,
Mathieu
GeoNetwork.
Gabriel
Gabriel Roldan
Hola Mathieu,
that sounds awesome, thanks.
I´ll be trying out more GN stuff these days and will try to report back any issues I find with a patch if I can.
Gabriel
Mathieu Coudert wrote:
Hola Gabriel,
Thanks again,
ciao,
Mathieu
