how can I change the encoding for PDF export? I need to use some special characters which aren’t supported with current encoding.
Thank you.
Marko
Thank you.
Marko
Hi again,
any help regarding this problem?
Thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/PDF-encoding-tp5056358p5057953.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Marko,
are you sure the problem is character encoding, not that the font is missing your character ?
Could you give an example of metadata text you want to export to PDF, which does not work ?
Kind regards,
Heikki Doeleman
On Wed, Jun 5, 2013 at 12:27 AM, mskvorc <marko.skvorc@anonymised.com> wrote:
Hi again,
Thank you
How ServiceNow helps IT people transform IT departments:
- A cloud service to automate IT design, transition and operations
- Dashboards that offer high-level views of enterprise services
- A single system of record for all IT processes
http://p.sf.net/sfu/servicenow-d2d-j
GeoNetwork-devel mailing list
I tried to change the font but without success. The problem is with croatian
letters like Č Ć Ž Š Đ, where Ž and Š are shown correctly.
The encoding should be windows-1250.
Marko
View this message in context: http://osgeo-org.1560.x6.nabble.com/PDF-encoding-tp5056358p5057995.html
Hi Marko
Here is the explanation of the issue: http://xmlgraphics.apache.org/fop/faq.html#pdf-characters
Seem GeoNetwork should embed the font, otherwise only LATIN1 characters are managed properly.
Going to open a issue to track about this.
Jose García
letters like Č Ć Ž Š Đ, where Ž and Š are shown correctly.The encoding should be windows-1250.
Marko–
View this message in context: http://osgeo-org.1560.x6.nabble.com/PDF-encoding-tp5056358p5057995.htmlSent from the GeoNetwork developer mailing list archive at Nabble.com.
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
