The latest BlueNetMEST’s PDFPrint fails on exception for me. Is there a known solution for this?
C:_work\geonetwork\BlueNet_MEST_SVN\web\geonetwork/xsl/portal-present-fop.xsl
2008-10-22 13:53:44,755 ERROR [jeeves.service] - → (C) message : org.xml.sax.SAXParseException: Invalid byte 2 of 4-byte UTF-8 sequence.
2008-10-22 13:53:44,755 ERROR [jeeves.service] - → (C) exception : XPathException
2008-10-22 13:53:44,755 DEBUG [jeeves.service] - Raised exception while executing service
XPathException
en
pdf.search
Thx,
Kevin Gunn
Software Engineer
Australian Institute of Marine Science
Ph: (07) 47534305
Fax: (07) 4772 5852
E-mail: k.gunn@anonymised.com
The information contained in this communication is for the use of the |
individual or entity to whom it is addressed, and may contain |
information which is the subject of legal privilege and/or copyright. |
If you have received this communication in error, please notify the |
sender by return E-Mail and delete the transmission, together with any |
attachments, from your system. Thank you. |
sender by return email and delete the transmission, together with any
