Hi Tania,
Plugin schemas might need to be able to supply javascript without having to alter the core javascript files in GeoNetwork - so all plugin schemas need to supply a template called 'schemaname'-javascript (the call is made to this template in web/geonetwork/xsl/metadata-edit.xsl). If you don't have any javascript specific to your profile then you can easily fix this by adding an empty template to your presentation xslt eg.
<xsl:template name="iso19139.eurac-javascript"/>
Check out the plugin schema iso19139.mcp as an example of a profile that needs to include javascript.
I have this down to add to the schema plugins documentation but it's bundled up with some other changes I've made for converters and dependencies that are yet to be committed (soon I hope).
Simon
________________________________________
Sent: Wednesday, 4 April 2012 11:43 PM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] personalized schema plugin error - XPathException
Hi Everyone!
I have been trying to develop a personalized metadata schema according to
the steps defined in the Trunk developer manual.
I have created all of the files specified.. and my personalized schema
appears in the schema list. but each time I want to edit a metadata an error
appears:
*""XPathException : Template iso19139.eurac-javascript has not been
defined""*
Has anyone faced this problem before? what was the solution?
Thank you very much for your help!!
Ciao,
Tania
GIS Software Engineer
View this message in context: http://osgeo-org.1560.n6.nabble.com/personalized-schema-plugin-error-XPathException-tp4686575p4686575.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Better than sec? Nothing is better than sec when it comes to
monitoring Big Data applications. Try Boundary one-second
resolution app monitoring today. Free.
GeoNetwork-devel mailing list
