[GeoNetwork-devel] Personalized Schema Plugin error
Hi All,
I have been developing a schema plugin for GN-trunk, currently is works
quite well. I can load it and open the metadata example.
But when I search for a metadata example which is part of this schema
plugin, it doesnt show.
I checked the log file and it shows this error:
2012-06-01 14:23:47,082 ERROR [geonetwork.index] - Indexing stylesheet
contains errors : Failed to compile stylesheet. 1 error detected.
2012-06-01 14:23:47,082 ERROR [geonetwork.datamanager] - The metadata
document index with id=1102 is corrupt/invalid - ignoring it. Error: Failed
Does anyone know what causes this and how to solve it?
Thank you!
Tania
View this message in context: http://osgeo-org.1560.n6.nabble.com/Personalized-Schema-Plugin-error-tp4978579.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Tania
From log message, seem either the file index-fields.xsl or language-index-fields.xsl of your profile has a bug. Check with xml validator that documents are well-formed.
Most probably is that the file output.log if using jetty or catalina.out in Tomcat, contain more useful information with the name of file and line where is failing.
Jose García
On Fri, Jun 1, 2012 at 5:26 PM, taniapf <tania.puspita@anonymised.com> wrote:
Hi All,
Thank you!
Tania
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
Hi Jose,
thanks for your reply. I am using jetty and GN Trunk. Its funny that I can
view the profile but when I search for metadata saved using that profile it
cant be found.
as you said it better to chech the output.log when using jetty, may you
point where the file is located?
Because in my GN installation I cant find such kind of file.
Thank you very much in advance!
Kind regards,
Tania
View this message in context: http://osgeo-org.1560.n6.nabble.com/Personalized-Schema-Plugin-error-tp4978579p4978890.html
Hi Tania
The output.log should be in jetty/logs folder. If using Windows, instead of the output.log file, log is send to the console, you need to check there.
Jose García
On Mon, Jun 4, 2012 at 9:30 AM, taniapf <tania.puspita@anonymised.com> wrote:
Hi Jose,
cant be found.
Kind regards,
Tania
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
