Hi, I am currently using BlueNetMEST 2.4. I am having an issue when uploading
records as an editor. In MEST 2.2, I was able to upload a record as an
editor and be able to view the record immediately. However, in MEST 2.4,
when the editor uploads a record, he cannot see it until the administrator
logs in and updates the record's privileges. This, of course, has proven to
be quite inconvenient. I found that this default behavior cannot be altered
through user-profiles.xml. I would really appreciate any help in the matter.
Thanks!
View this message in context: http://n2.nabble.com/Possible-bug-tp4613501p4613501.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Hi Trishal,
Check out svn rev 5791 - changes to src/org/fao/geonet/kernel/mef/Importer.java
Simon
________________________________________
Sent: Tuesday, 23 February 2010 4:01 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Possible bug??
Thanks!
Download Intel® Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
GeoNetwork-devel mailing list
Thanks Simon. It works great. Thanks again!!
View this message in context: http://n2.nabble.com/Possible-bug-tp4613501p4620910.html
