[GeoNetwork-devel] possible error in GN map configuration source?
Just pointing out so that someone can correct it, if needed.
I was browsing through the source when I came across this file.
https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/maps/mapviewer.wmc
I see the following repeated twice (nested) in the document
<?xml version="1.0" encoding="utf-8" standalone="no" ?>
<ViewContext …>…
It this on purpose? or can we remove the nested <?xml …> and the containing for the ‘Countries’ layer?
Please verify the same.
Regards
Ameet
You’re right Ameet, Thank for reporting.
Fixed https://github.com/geonetwork/core-geonetwork/blob/develop/web/src/main/webapp/maps/mapviewer.wmc
Francois
2014/1/22 Ameet Chaudhari <ameet.chaudhari@anonymised.com1…>
<ViewContext …>…
Regards
Ameet
CenturyLink Cloud: The Leader in Enterprise Cloud Services.
Learn Why More Businesses Are Choosing CenturyLink Cloud For
Critical Workloads, Development Environments & Everything In Between.
Get a Quote or Start a Free Trial Today.
http://pubads.g.doubleclick.net/gampad/clk?id=119420431&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
