[GeoNetwork-devel] post processing xsl on save
Hi All,
When we edit a record and Save, is there a way to remove blank elements (which don’t have values entered) from xml? Is there any XSL for processing on-Save or any mechanism where I can add new xsl to the on-save processing.
Or do I have to do this in the called service only?
(GN 2.10.x)
Thanks
Ameet
The update-fixed-info.xsl transform in the schema-plugins folder is ran on a metadata on save. You can update that to make the changes you want.
On Thu, Mar 27, 2014 at 7:50 AM, Ameet Chaudhari <ameet.chaudhari@anonymised.com…31…> wrote:
Hi All,
(GN 2.10.x)
Thanks
Ameet
GeoNetwork-devel mailing list
Okay great. Thanks a lot.
Ameet
On Thu, Mar 27, 2014 at 1:26 PM, Jesse Eichar <jesse.eichar@anonymised.com> wrote:
Systems Programmer
kCube Consultancy Services
Hi All,
(GN 2.10.x)
Thanks
Ameet
