[GeoNetwork-devel] problem about geonetwork2.1
1 I use postgist database when i create new metadata file in geonetwork. i
can't see metadata file in my database(my database name geonetwork in
postgist)
2 when i use batch import function its show message " the requested
operation could not be performed " and "Exception:Directory not found:
c:\test.xml"( my file store in path c:\test.xml)
3 when i use XML Metadata insert function its show message " the requested
operation could not be performed " and "UnknowHostException : www.fgdc.gov"
thank you
View this message in context: http://www.nabble.com/problem-about-geonetwork2.1-tp15151123s18419p15151123.html
Sent from the geonetwork-devel mailing list archive at Nabble.com.
