gco:Date should allow these formats: date (YYYY-MM-DD), yearmonth(YYYY-MM) and year (YYYY), so initially the year format should be fine. Have you check if works fine in the ISO19139 profile? Just to discard a bug in the date control used in GeoNetwork.
On Mon, Oct 17, 2016 at 8:03 PM, Jo Cook <jocook@anonymised.com> wrote:
Hi Jose,
I have partially solved this- the schema profile that I had originally copied (I can’t remember which one) had the gco:date section in schema-suggestions.xml commented out. I have uncommented that and can now add a new date. However in testing this, I have noticed that not all the date formats given in the dropdown list work correctly. I have not fully investigated this yet but I don’t seem to be able to store dates if I choose “Year Only”.
I don’t fully understand where these are defined but probably need to look at the log files to see if there are any errors first.
Thanks
Jo
Astun Technology Ltd, The Coach House, 17 West Street, Epsom, Surrey, KT18 7RL, UK
t:+44 1372 744 009 w: astuntechnology.com twitter:@astuntech
iShare - enterprise geographic intelligence platform
GeoServer, PostGIS and QGIS training
Helpdesk and customer portal
Company registration no. 5410695. Registered in England and Wales. Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no. 864201149.
On Mon, Oct 17, 2016 at 6:29 AM, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Jo
Can you point to the changes you’ve done in the GEMINI 2.2 schema to check?
Jose García
Jo Cook
t:+44 7930 524 155/twitter:@archaeogeek
On Fri, Oct 14, 2016 at 12:15 PM, Jo Cook <jocook@anonymised.com> wrote:
Hi List,
I’ve got a schema here: https://github.com/AstunTechnology/iso19139.gemini22_GN3 based on ISO19139. This is mainly working in Geonetwork 3.0.x apart from adding a new Citation Date.
I’ve got it set so that the plus button for adding a new date appears in both default or full view when editing. However when this is clicked, nothing appears to happen. When I look at the XML I can see that the following snippet is added:
gmd:date
gmd:CI_Date
gmd:dateType
<gmd:CI_DateTypeCode codeList=“http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_DateTypeCode”
codeListValue=“”/>
</gmd:dateType>
</gmd:CI_Date>
</gmd:date>
This is incorrect. What it should be is:
gmd:date
gmd:CI_Date
gmd:date
gco:Date/
</gmd:date>
gmd:dateType
<gmd:CI_DateTypeCode codeListValue=“publication”
codeList=“http://standards.iso.org/ittf/PubliclyAvailableStandards/ISO_19139_Schemas/resources/Codelist/ML_gmxCodelists.xml#CI_DateTypeCode”>publication</gmd:CI_DateTypeCode>
</gmd:dateType>
</gmd:CI_Date>
</gmd:date>
The correct snippet is added in ISO19139 so I know it’s something in my code, but I don’t know where this snippet would be defined. I can’t see it in config-editor.xml or layout.xsl. If someone could explain how that should work, I’d be really grateful.
Thanks
Jo
Jo Cook
engaging tech sites, SlashDot.org! http://sdm.link/slashdot
GeoNetwork-devel mailing list
GeoNetwork-devel@anonymised.comorge.net
Vriendelijke groeten / Kind regards,
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
T: +31 (0)318 416664
Please consider the environment before printing this email.
Jose García
Veenderweg 13
6721 WD Bennekom
The Netherlands
