I just tried to compile the docs and it seems to be hanging.
I noticed that the docs submodule is no longer required since it was merged
into the 2.10.x branch. I don't see how this merge could be related since it
is simply a copy of the data. But it was working OK a couple weeks ago when
I made my last attempt.
Just wondering if anyone has the same issue.
Here are the steps I have taken to perform the build...
git clone https://github.com/geonetwork/core-geonetwork.git geonetwork-2.10
cd geonetwork-2.10
git checkout 2.10.x
git submodule update --init
# Test build
mvn clean install
mvn assembly:assembly
# Compiled successfully
#Edit web/pom.xml
#Remove "<resource>" comments block in order to build eng documents. Right
under the following comment.
cd docs
mvn clean install
# it runs for a bit an then hangs at "[INFO] l.3756
...-configuration/geonetwork-data-dirs.png}"
Here are the last of the log messages....
Thank you.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-Building-2-10-x-docs-tp5058714.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Seems like geonetwork-data-dirs.png was not copied over to during the move
from core-doc-sources to the core-geonetwork.
core-doc-sources 2.10.x /eng/users/source/admin/advanced-configuration
<https://github.com/geonetwork/core-doc-sources/tree/2.10.x/eng/users/source/admin/advanced-configuration>
core-geonetwork 2.10.x /docs/eng/users/source/admin/advanced-configuration
<https://github.com/geonetwork/core-geonetwork/tree/2.10.x/docs/eng/users/source/admin/advanced-configuration>
I moved the file to that folder and all worked well.
Could someone add this missing file.
Thanks.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-Building-2-10-x-docs-tp5058714p5059087.html
Hi Ian,
there is also other missing files
[INFO] LaTeX Warning: File
`quickstartguide/new_metadata/link/geonetwork-relation-mana
[INFO] ger.png' not found on input line 1376.
I'll look into that. I can't figure out why/when they have been removed
Francois
2013/6/10 ianwallen <ianwallen@anonymised.com>:
Thanks.
How ServiceNow helps IT people transform IT departments:
1. A cloud service to automate IT design, transition and operations
2. Dashboards that offer high-level views of enterprise services
3. A single system of record for all IT processes
http://p.sf.net/sfu/servicenow-d2d-j
GeoNetwork-devel mailing list
THe reason is because of an ignore in the root .gitignores. It was geonetwork-*
I think I have removed that.
On Tue, Jun 11, 2013 at 9:00 AM, Francois Prunayre <fx.prunayre@anonymised.com.31…> wrote:
Hi Ian,
[INFO] ger.png’ not found on input line 1376.
I’ll look into that. I can’t figure out why/when they have been removed
Francois
2013/6/10 ianwallen <ianwallen@anonymised.com22…>:
Thanks.
- A cloud service to automate IT design, transition and operations
- Dashboards that offer high-level views of enterprise services
- A single system of record for all IT processes
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Ok, so I could get latest core-doc-sources and copy on doc folder for
develop and 2.10.x branches and commit all the missing files.
Does it sound fine ?
Francois
2013/6/11 Jesse Eichar <jesse.eichar@anonymised.com>:
geonetwork-*
On Tue, Jun 11, 2013 at 9:00 AM, Francois Prunayre <fx.prunayre@anonymised.com>
wrote:
Hi Ian,
Francois
> move
> Thanks.
Fixed on develop and 2.10.x.
Francois
2013/6/11 Francois Prunayre <fx.prunayre@anonymised.com>:
Francois
geonetwork-*
wrote:
Hi Ian,
Francois
> move
> Thanks.
