[GeoNetwork-devel] Problem in geonetwork-core with documentation
Am I correct that there is still documentation that is maintained inside the geonetwork-core instead of in core-doc-sources? I see updates within the docs folder, while all documentation also sits in the core-doc-sources repository.
I think this is incorrect and requires correcting ASAP. I think the docs folder should be removed from the geonetwork-core, unless we have good reasons to remove core-doc-sources (maybe because we will have more documentation maintained next to the code!?).
Jeroen
Hi Jeroen
The docs was initially a sub-module in github, but last summer in Bolsena meeting was removed and moved the docs to each branch.
Similar with other sub-modules as was a bit painful to manage them. Still using some submodules for geoserver and maven_repo, that hopefully can be removed no so far.
Jose García
On Thu, Jan 30, 2014 at 5:17 PM, Jeroen Ticheler <jeroen.ticheler@anonymised.com> wrote:
Jeroen
WatchGuard Dimension instantly turns raw network data into actionable
security intelligence. It gives you real-time visual feedback on key
security issues and trends. Skip the complicated setup - simply import
a virtual appliance and go from zero to informed in seconds.
http://pubads.g.doubleclick.net/gampad/clk?id=123612991&iu=/4140/ostg.clktrk
GeoNetwork-devel mailing list
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer and GeoNetwork. Visit http://geocat.net for details.
Jose García
GeoCat bv
Veenderweg 13
6721 WD Bennekom
The Netherlands
http://GeoCat.net
