first of all thanks for your work and congratulations for the new GN release!
There is a small problem in the harvesting management.
Indeed, when you want to add an harvesting task, there is nothing in the liste where you choose the type of harvesting task. This problem only appears when you choose French or Spanish as language.
I changed harvesting.xml file for fr and es language in order to fill the empty type list.
Here you have my patch if you want to change it!
HTH,
Mathieu COUDERT
(attachments)
harvesting_fr.diff (1.04 KB)
harvesting_es.diff (1.02 KB)
