[GeoNetwork-devel] Problem indexing field in Lucene
I am indexing the contentInfo in Lucene modifying the index-fields.xsl to iso19139, exactly I am added this:
<xsl:for-each select=“//gmd:contentInfo/gmi:MI_CoverageDescription/gmd:dimension”>
</xsl:for-each>
my problem is that, although token is false, when I rebuild the index, the variable name sea_water_salinity, for example, would become sea water salinity without “_”, I am investigated about this but I have found nothing
Thanks to all.
Micho Garcia
GIS Developer Artisan
http://michogarcia.org
