[GeoNetwork-devel] Problem with searching
Hey to everyone :slight_smile:
We have some problem here with GeoNetwork. :frowning: Translation in macedonian is
done but now we have problem with searching in *Cyrillic alphabet*. Any
suggestions how to do it ???
Thanks :slight_smile:
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-with-searching-tp5010285.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Searching is a rather complicated issue so it could be one of many issues. Could you give me a few example searches along with the expected results?
Jesse
done but now we have problem with searching in Cyrillic alphabet. Any
โ€“
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_sfd2d_oct
GeoNetwork-devel mailing list
setting URIEncoding to UTF-8 helped for norwegian letters, maybe it helps for cyrillic letters also.
example
<Connector port="8080" URIEncoding="UTF-8"/>
from
https://confluence.atlassian.com/display/DOC/Configuring+Tomcatโ€™s+URI+encoding
kind regards
Jรธrn-Vegard Rรธsnes
----- Original Message -----
Fra: "lennyM" <l.miovska@anonymised.com>
Til: geonetwork-devel@lists.sourceforge.net
Sendt: 22. oktober 2012 16:19:05
Emne: [GeoNetwork-devel] Problem with searching
macedonian is
Any
Nabble.com.
CONFIDENTIALITY
This e-mail and any attachment contain KONGSBERG information which may be
proprietary, confidential or subject to export regulations, and is only meant
for the intended recipient(s). Any disclosure, copying, distribution or use is
prohibited, if not otherwise explicitly agreed with KONGSBERG. If received in
error, please delete it immediately from your system and notify the sender
properly.
Problem solved.. thank you :slight_smile:
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-with-searching-tp5010285p5010721.html
