[GeoNetwork-devel] Problem with the map
Hello,
i have download and install the geonetwork,when i open the main page in geonetwork,i can’t see the map.can you help with that problem plz?
Assuming you have installed with the installer you should be able to go to localhost:8080/geoserver. Make sure it is working. You can also look at localhost:8080 and it will show you all the available servlets for that server.
Jesse
On Thu, Nov 1, 2012 at 4:33 PM, George Thivaios <gthivaios01@anonymised.com> wrote:
Hello,
Everyone hates slow websites. So do we.
Make your web apps faster with AppDynamics
Download AppDynamics Lite for free today:
http://p.sf.net/sfu/appdyn_sfd2d_oct
GeoNetwork-devel mailing list
If the maps are shown when you access it via localhost but not when you
access it from another computer then you may need to edit the file
"config-gui.xml" and change all the reference of "localhost" to the name of
your server.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-with-the-map-tp5013340p5013356.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
