[GeoNetwork-devel] Problems compiling latest version from clean checkout from github
Hey,
I just checked out the latest version from github and am having
problems compiling ...
First off, I assume that I just need to clone core-geonetwork in order
to get things working right?
The error I get when using mvn clean install on core-geonetwork is a
failed test inside Jeeves:
- Running jeeves.server.ConfigurationOveridesTest
   Tests run: 5, Failures: 2, Errors: 2, Skipped: 0, Time elapsed:
0.275sec <<< FAILURE!
   Results :
   Failed tests:
updateConfig(jeeves.server.ConfigurationOveridesTest):
expected:<[fre]> but was: <[eng]>
       loadFile(jeeves.server.ConfigurationOveridesTest):
expected:<CREATE TABLE [New]Relations> but was :<CREATE TABLE
Relations>
   Tests in error:
       updateLoggingConfig(jeeves.server.ConfigurationOveridesTest):
The resource file /WEB-INF/logfile1.properties is not a file and not a
web resource: null. Perhaps a leading / was forgotten?
       imports(jeeves.server.ConfigurationOveridesTest): The resource
file /WEB-INF/overrides-config.xml is not a file and not a web
Does anyone have any ideas what might be causing this?
If I remove the test then I get errors when I attempt to start
geonetwork (having built an installer and used it) stating that a
database initialization failed. Stopping the server and starting it
again does then say it deploys, however it spits up a database error
in the browser then. I have attached files containing the error
messages that I got from this (first_start.log, second_start.log,
geonetwork error in browser.txt).
Thanks for any help you can offer,
Elgar Storm
PS I have attached the log files for the jeeves test crash
(jeeves.server.ConfigurationOveridesTest.txt,
TEST-jeeves.server.ConfigurationOveridesTest.xml)
(attachments)
jeeves.server.ConfigurationOveridesTest.txt (11.8 KB)
TEST-jeeves.server.ConfigurationOveridesTest.xml (17.7 KB)
first_start.log (49.4 KB)
geonetwork error in browser.txt (6.49 KB)
second_start.log (51.3 KB)
Just guessing but I think it is probably related to the path separators. I need to run windows to test I think. Are you building on windows?
Jesse
On Wed, Jun 20, 2012 at 8:02 AM, Elgar Storm <elgarstorm@anonymised.com> wrote:
Hey,
problems compiling …
  • Running jeeves.server.ConfigurationOveridesTest
Results :
Failed tests:
Relations>
Tests in error:
Elgar Storm
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
I have made a change so the build will hopefully work on windows. But I don’t have enough information about why it is not starting for you. Some additional information:
what command are you using to start geonetwork?
Try updating and doing a full build. I changed how configuration overrides are resolved so hopefully it will solve your problem.
Jesse
On Wed, Jun 20, 2012 at 10:19 AM, Jesse Eichar <jesse.eichar@anonymised.com.> wrote:
Jesse
Hey,
Results :
Failed tests:
Relations>
Tests in error:
Elgar Storm
Hi Jesse,
I cloned the 2.8.x-repository yesterday and experience the very same problem
when trying to build (2 of 5 surefire-tests fail). Any idea what I could do
to fix this?
Best regards and thanks in advance
Max Stephan
don't have enough information about why it is not starting for you. Some
overrides
Jesse
&lt;
jesse.eichar@
Jesse
On Wed, Jun 20, 2012 at 8:02 AM, Elgar Storm &lt;
elgarstorm@
&gt; wrote:
Hey,
  Results :
  Failed tests:
expected:
but was :
<CREATE TABLE
Relations>
  Tests in error:
Elgar Storm
Exclusive live event will cover all the ways today's security and
Discussions
malware
GeoNetwork-devel@anonymised.com
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problems-compiling-latest-version-from-clean-checkout-from-github-tp4982574p5023041.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
Could you email me the surefire test result files?
On Fri, Dec 14, 2012 at 2:30 PM, Max Stephan <max.stephan@anonymised.com> wrote:
Hi Jesse,
to fix this?
Max Stephan
overrides
Jesse
jesse.eichar@
Jesse
elgarstorm@
> wrote:
Hey,
Results :
Failed tests:
expected:
but was :
<CREATE TABLE
Relations>
Tests in error:
Elgar Storm
Discussions
malware
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
Sure, here you go.
Sent: 14 December 2012 14:33
To: Max Stephan
Cc: Devel geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Problems compiling latest version from clean checkout from github
On Fri, Dec 14, 2012 at 2:30 PM, Max Stephan <max.stephan@…458…> wrote:
Hi Jesse,
to fix this?
Max Stephan
overrides
Jesse
jesse.eichar@
Jesse
elgarstorm@
> wrote:
Hey,
Results :
Failed tests:
expected:
but was :
<CREATE TABLE
Relations>
Tests in error:
Elgar Storm
Discussions
malware
GeoNetwork-devel@…925…
(attachments)
jeeves.server.ConfigurationOveridesTest.txt (11.5 KB)
I investigated a bit in the meantime and the cause of the problem is that the
test-case tries to access the files "logfile1.properties" and
"/WEB-INF/overrides-config.xml" (which is obvious looking at the
test-results). But in addition to the fact that those files don´t exist the
folder where the test-suite is searching for them doesn´t exist as well. The
folder would be
<geonetwork-base-folder>\jeeves\target\test-classes\correct-webapp whereas
there´s no "testclasses"-folder at all in the target-directory. Don´t know
what the reason for this might be but hope this remarks are of any help.
Best regards
Max Stephan
Max Stephan wrote
Sure, here you go.
jesse.eichar@
To: Max Stephan
Cc: Devel
geonetwork-devel@anonymised.com
On Fri, Dec 14, 2012 at 2:30 PM, Max Stephan &lt;
max.stephan@
&lt;mailto:
max.stephan@
&gt;> wrote:
Hi Jesse,
problem
do
to fix this?
Max Stephan
overrides
Jesse
&lt;
jesse.eichar@&lt;mailto:jesse.eichar@>
Jesse
elgarstorm@
&gt; wrote:
Hey,
  Results :
  Failed tests:
expected:
but was :
<CREATE TABLE
Relations>
  Tests in error:
Elgar Storm
Discussions
malware
GeoNetwork-devel@anonymised.com&lt;mailto:GeoNetwork-devel@anonymised.com>
&lt;mailto:
&gt;
jeeves.server.ConfigurationOveridesTest.txt (15K)
&lt;http://osgeo-org.1560.n6.nabble.com/attachment/5023048/0/jeeves.server.ConfigurationOveridesTest.txt&gt;
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problems-compiling-latest-version-from-clean-checkout-from-github-tp4982574p5023082.html
OK, problem solved. I moved the Geonetwork-sources to a folder without blanks
in the folder-name. Now the build-process is running smoothly.
the test-case tries to access the files "logfile1.properties" and
the folder where the test-suite is searching for them doesn´t exist as
well. The folder would be
\jeeves\target\test-classes\correct-webapp whereas there´s no
"testclasses"-folder at all in the target-directory. Don´t know what the
Best regards
Max Stephan
Max Stephan wrote
Sure, here you go.
jesse.eichar@
To: Max Stephan
Cc: Devel
max.stephan@
&lt;mailto:
max.stephan@
&gt;> wrote:
Hi Jesse,
problem
do
to fix this?
Max Stephan
Some
overrides
Jesse
&lt;
separators.
Jesse
elgarstorm@
&gt; wrote:
Hey,
  Results :
  Failed tests:
expected:
but was :
<CREATE TABLE
Relations>
  Tests in error:
Elgar Storm
Discussions
malware
Discussions
malware
&lt;mailto:
&gt;
View this message in context: http://osgeo-org.1560.n6.nabble.com/Problems-compiling-latest-version-from-clean-checkout-from-github-tp4982574p5023088.html
