I am testing the BlueNetMEST version of geonetwork.
I have downloaded the latest version from the sandbox and it compiles and runs correctly on my Mac OS X 10.5.6 system
BlueNet Source: geonetwork.svn.sourceforge.net/viewvc/geonetwork/sandbox/BlueNetMEST rev 6076"
testing with all defaults, jetty and embedded database.
When I run the dist install file on the suse system, or when I checkout and build directly on the suse system I get this problemDEBUG [jeeves.engine] - Raised exception while starting appl handler. Skipped.DEBUG [jeeves.engine] - Handler : org.fao.geonet.GeonetworkDEBUG creating bean with name ‘org.springframework.context.annotation.internalCommonAnnotationProcessor’: Initialization of bean failed; nested exception is java.lang.NullPointerException…Caused by: java.lang.NullPointerExceptionat org.springframework.core.GenericTypeResolver.getTypeVariableMap(GenericTypeResolver.java:144)full logfile attached.This same machine runs correctly the trunk geonetwork release 2.4.2Any suggestions welcome. Andrew
More details:
JAVA
java version “1.6.0”
Java™ SE Runtime Environment (build pxa6460sr7-20091215_02(SR7))
IBM J9 VM (build 2.4, JRE 1.6.0 IBM J9 2.4 Linux amd64-64 jvmxa6460sr7-20091214_49398 (JIT enabled, AOT enabled)
J9VM - 20091214_049398
JIT - r9_20091123_13891
GC - 20091111_AA)
JCL - 20091202_01
OS
LSB_VERSION=“core-2.0-noarch:core-3.2-noarch:core-4.0-noarch:core-2.0-x86_64:core-3.2-x86_64:core-4.0-x86_64”
SUSE Linux Enterprise Server 11 (x86_64)
VERSION = 11
PATCHLEVEL = 0
Andrew Watkins
Systems Development Team Manager
National Institute Water & Atmospheric Research (NIWA).
NIWA is the trading name of the National Institute of Water & Atmospheric Research Ltd.
(attachments)
geonetwork.log (28.1 KB)
