Hi Jeroen,
Thanks for the reply. It looks like a case for the Australian developers.
John
-----Original Message-----
From: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Sent: Tuesday, 5 February 2008 6:12 PM
To: Hockaday John
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Problems with multiple
GeoNetwork instances onthe same domain [SEC=UNCLASSIFIED]Hi John,
I don't think that this issue is one that's high on anyone's list at
the momentIndeed it would be a nice cleanup, but also one that
someone else could pick up
Using GAST, only the servlet name of geonetwork can be
changed for the
Jetty servlet engine (only Jetty). A configuration is also
required In
the Admin interface. Indeed, intermap and geoserver are at present
much more hardcoded in the geonetwork servlet.
Ciao,
JeroenOn Jan 29, 2008, at 1:55 AM, John.Hockaday@anonymised.com wrote:
> Hi All,
> We have a requirement to setup multiple copies of GN on our on web
> server
> domain. We have found that the configuration of the GN
installation
> script
> doesn't allow us to do this seamlessly. Changing the location of
> the GN
> servlet web address from /geonetwork/ to something else
like /asdi/
> only
> changes a few locations where the /geonetwork/ string is
located in
> the
> software.
> We also found that it is difficult to locate intermap and
geoserver in
> different locations other than /intermap/ and /geoserver/. GN
> expects to find
> these servlets at those locations where we wish to have multiple
> instances of
> them so that they can be configured to suite the different
section's
> needs.
> Are the developers addressing this problem of locating GN and its
> component
> software in locations other than the expected /geonetwork/, /
> intermap/ and
> /geoserver/?
> Thanks.
> John Hockaday
> Geoscience Australia
> GPO Box 378
> Canberra ACT 2601
> (02) 6249 9735
> http://www.ga.gov.au/
> john.hockaday\@ga.gov.au
> This SF.net email is sponsored by: Microsoft
> Defy all challenges. Microsoft(R) Visual Studio 2008.
> http://clk.atdmt.com/MRT/go/vse0120000070mrt/direct/01/
> GeoNetwork-devel mailing list
> GeoNetwork-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-devel
> GeoNetwork OpenSource is maintained at
