Hello.
First at all… this is my first deep contact with the GN 2.1.0 source.
I’m working with Windows XP and Eclipse and/or JBuilder 2007 (a curious brother of Eclipse with a price included.)
I know there are other Tomcat comments in the last messages, but I would like to confirm if there is a solution.
- Tomcat 5.5
Everything is right with Jetty, but the Upper Left Map doesn’t work correctly with Tomcat. I have seen this comment in other messages. Is there any solution to this problem?
- SVN.
When I try to use TortoiseSVN, or the Subversion plugin in Eclipse to connect to the SVN repository, I must write an username and password.
I haven’t found them in the documentation or web. Only the old CVS information make reference to “anonymous” and “geonetwork”. But… it doesnt work to me.
Is my proxy?
Thanks.
Alberto Amaro
Metadata Project Manager
Earth Observation Department
INTA
___________________________________________________________________ Este mensaje se dirige exclusivamente a su destinatario y puede contener información privilegiada o CONFIDENCIAL. Si vd. no es la persona a quien se dirige este mensaje, queda notificado de que la utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente por esta misma vía y proceda a su destrucción. This message is intended exclusively for its addressee and may contain information that is CONFIDENTIAL and protected by professional privilege. If you are not the intended recipient you are hereby notified that any dissemination, copy or disclosure of this communication is strictly prohibited by law. If this message has been received in error, please immediately notify us via e-mail and delete it. ___________________________________________________________________
