In Jeeves we have a profile manager and a flexible solution where many profiles can theoretically be defined in configuration files. However in our UI and much of our code the profiles are hardcoded. This implies to me that this extra flexibility is unnecessary.
I would like to replace it with an enum of the profiles Geonetwork actually uses. This way, rather than depending on hardcoded strings or references to constants we can be sure we are actually referencing real profiles.
Any complaints about this?
Jesse
Hi Jesse,
Do you refer tot metadata profiles (the plugins)?
Jeroen
GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on GeoServer, MapServer, PostGIS and GeoNetwork. Visit http://geocat.net for details.
_________________________
Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
Tel: +31 (0)6 81286572
http://geocat.net
Op 26 jun. 2013 om 07:26 heeft Jesse Eichar <jesse.eichar@anonymised.com> het volgende geschreven:
Jesse
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
GeoNetwork-devel mailing list
No I am referring to Administrator, RegisterdUser, Editor, etc…
On Wed, Jun 26, 2013 at 8:41 AM, Jeroen Ticheler <jeroen.ticheler@…437…> wrote:
Hi Jesse,
Jeroen
Jeroen Ticheler
GeoCat bv
Veenderweg 13
6721 WD Bennekom
http://geocat.net
Jesse
