[GeoNetwork-devel] Proposal: Display function for system logs
We note that many of the errors which occur during harvesting are
written to the Jetty logs but are not actually visible to anyone
administering the site remotely. We propose to add a simple, read-only
log file viewing function to the administrative interface so that errors
can more easily be tracked.
Archie
-- Archie Warnock warnock@anonymised.com
-- A/WWW Enterprises www.awcubed.com
-- As a matter of fact, I _do_ speak for my employer.
Good idea! Indeed only visible to administrators :slight_smile:
Jeroen
Archie
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-devel mailing list
Yes - absolutely.
Archie
It would be great if the Z3950 gateway logs could store appropriate information and be analysed. The ASDD does such reports on the ZAP gateway logs (See any of the reports at http://asdd.ga.gov.au/asdd/tech/gatewaystats/).
It would also be good to have the Z3950 server logs to be analysed to determine what people are searching for etc.
Just my two cents worth.
John
-----Original Message-----
From: Jeroen Ticheler [mailto:Jeroen.Ticheler@anonymised.com]
Sent: Tuesday, 17 November 2009 4:19 AM
To: Archie Warnock
Cc: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] Proposal: Display function
for system logs
Jeroen
> only
> errors
> Archie
> 30-Day
> focus on
Reports 2008 30-Day
Why yes... yes, it would :wink:
Archie
Hello Archie,
2009/11/16 Archie Warnock <warnock@anonymised.com>:
What happens if using Tomcat, log file path could be different ?
Cheers.
Francois
Archie
Presumably that would be a configuration option, either added to gast or
to the admin menu of GN.
Archie
