[GeoNetwork-devel] proposal Improved WMC support in geonetwork
Hi list, i’d like to propose for voting this improvement proposal, to be released in the 2.9/3.0 release:
http://trac.osgeo.org/geonetwork/wiki/proposals/OpenWMCfromCatalogue
The user will get the possibility to add a iso19139 record describing a map-context. The map context document (for example generated by geonetwork map viewer) can be attached to the record as an onlineresource (upload). When a WMC-iso19139 record is discovered in the catalogue a button will be displayed to open the attached WMC in the geonetwork map viewer.
Upload WMC
Currently a WMC can only be set by entering a url, it would be nice if people can upload it as a file
In case of WMC-attachement show an Open Map button
If protocol is OGC:WMC, then show a link to open the WMC document
Extend the WMCManager.js
The WMCManager gets an additional method to load a WMC file from a url
Any comments, let me know…
+1. It is a useful bit of functionality that I am sure I can make sure of in other projects like Georchestra for example.
I would like to see a diff or pull request. The zip you attached seemed to be the fully modified files and I don’t have time to try to pull the patch out of that.
On Fri, Nov 30, 2012 at 1:59 PM, Paul van Genuchten <paul.vangenuchten@anonymised.com…> wrote:
Upload WMC
Keep yourself connected to Go Parallel:
TUNE You got it built. Now make it sing. Tune shows you how.
http://goparallel.sourceforge.net
GeoNetwork-devel mailing list
+1 for me Paul.
With regard to WMC support, it could be also nice to extend that in order to:
  • from the mapviewer directly create an ISO19139 record from the current map as WMC (using the XSL transformation OGCWMC-to-ISO19139.xsl available): in one click the metadata is created and the WMC saved and attached to the metadata … and even maybe a thumbnail automatically created
  • be able to configure the mapviewer based on WMC (instead of XML or JS like now). From the administration, user could choose the WMC to use (default, OSM, …)
That could make easier the creation of catalog of maps.
I also like your remark about “enable users to comment” and that could be relevant for all metadata records with a public and a private discussion.
Cheers.
Francois
2012/12/7 Jesse Eichar <jesse.eichar@anonymised.com>
On Fri, Nov 30, 2012 at 1:59 PM, Paul van Genuchten <paul.vangenuchten@anonymised.com> wrote:
Upload WMC
LogMeIn Rescue: Anywhere, Anytime Remote support for IT. Free Trial
Remotely access PCs and mobile devices and provide instant support
Improve your efficiency, and focus on delivering more value-add services
Discover what IT Professionals Know. Rescue delivers
http://p.sf.net/sfu/logmein_12329d2d
