The proposal below still had no votes received. The proposal should be discussed in the next IRC meeting and then go up for voting once more I suggest.
Ciao,
Jeroen
Hi list,
On TabbedView – GeoNetwork opensource Developer website there is a proposal
for adding tabs to both the metadata view (of a single metadata record)
and the metadata editor.
These tabs improve usability, especially if metadata becomes big and
complex.. A first implementation already has been done in the NGR
project; integrating this into GN trunk would be fairly easy.
So, PSC members, please vote on this proposal.
Best regards,
Thijs Brentjens
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-devel mailing list
