[GeoNetwork-devel] Proposal to add Coordinate reference system selection panel
Dear PSC members,
Here is a proposal to add a CRS selection panel to the editor.
The proposal is here [1] and patch here [2].
Thanks for your votes, Regards.
Francois
[1] http://trac.osgeo.org/geonetwork/wiki/CRSSelection
[2] http://trac.osgeo.org/geonetwork/attachment/wiki/CRSSelection/CRSSelectionPanel.patch
Hi Francois,
I like the idea of being able to select a coordinate reference system from an EPSG list. I've looked at the crs.xsl and it seems that the elements are not from the ISO 19139 CT_CrsCatalogue. Is that the case? Can the code read an ISO 19139 CT_CrsCatalogue XML file? If not I would strongly suggest that this also be included.
Thanks.
John
-----Original Message-----
From: Francois Prunayre [mailto:fx.prunayre@anonymised.com]
Sent: Wednesday, 3 March 2010 9:03 PM
To: Andrea Carboni; Patrizia Monteduro; Archie Warnock; Simon
Pigot; Emanuele Tajariol; GeoNetwork Developer list
geonetwork-devel@lists.sourceforge.net; Jeroen Ticheler
Subject: [GeoNetwork-devel] Proposal to add Coordinate
Dear PSC members,
Francois
[2]
Download Intel® Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
http://p.sf.net/sfu/intel-sw-dev
GeoNetwork-devel mailing list
Hello John,
2010/3/4 <John.Hockaday@anonymised.com>:
Hi Francois,
True, as mentionned in the proposal, the CRS search service use the
GeoTools EPSG database we already have in our dependencies.
Using CT_CrsCatalogue, is another option which require more works at
least on some points I think:
* search engine : how to search in the CT_CrsCatalogue (eg. Lucene)
* handle xpointer
* (optional) allow viewing/editing of the CT_CrsCatalogue
We have a CT_CrsCatalogue in GeoNetwork 19139 schema directory, but it
looks to be only a sample one with 5 systems in it. Do you know if a
more complete document exist somewhere ? or if users are supposed to
create their own ?
At least the client side interface could be the same and we could make
another crs search service implementation based on CT_CrsCatalogue on
future release.
I updated the proposal with your comments. Thanks.
Francois
Thanks.
John
Dear PSC members,
Francois
[2]
Download Intel&#174; Parallel Studio Eval
Hi Francois,
Great! That was on my to-do-list!
Hope it gets a few +1's.
    Michael
Sent: Wednesday, 3 March 2010 6:03 PM
Pigot, Simon (CMAR, Hobart); Emanuele Tajariol; GeoNetwork
Developer list geonetwork-devel@lists.sourceforge.net; Jeroen Ticheler
Dear PSC members,
Francois
[2]
Hello,
Indeed, that’s great!
As a community member I would like to give you my +1! :wink:
Ciao,
Mathieu
On Thu, Mar 4, 2010 at 9:55 AM, Michael.Stegherr@anonymised.com wrote:
Hi Francois,
Hope it gets a few +1’s.
Michael
Dear PSC members,
Francois
[2]
Great Francois, +1 from me
Jeroen
On 3 mrt 2010, at 11:02, Francois Prunayre wrote:
Dear PSC members,
Francois
[1] CRSSelection – GeoNetwork opensource Developer website
[2] CRSSelectionPanel.patch on CRSSelection – Attachment – GeoNetwork opensource Developer website
Hi Francois,
Definitely +1 from me.
Cheers and thanks,
Simon
________________________________________
From: Francois Prunayre [fx.prunayre@anonymised.com]
Sent: Wednesday, 3 March 2010 9:02 PM
To: Andrea Carboni; Patrizia Monteduro; Archie Warnock; Pigot, Simon (CMAR, Hobart); Emanuele Tajariol; GeoNetwork Developer list geonetwork-devel@anonymised.comts.sourceforge.net; Jeroen Ticheler
Subject: Proposal to add Coordinate reference system selection panel
Dear PSC members,
Francois
+1
   Ciao,
   Emanuele
Alle 11:02:50 di mercoledì 3 marzo 2010, Francois Prunayre ha scritto:
Dear PSC members,
Francois
[2]
anel.patch
--- Download Intel&#174; Parallel Studio Eval
On 3/3/2010 6:32 PM, John.Hockaday@anonymised.com wrote:
Hi Francois,
I support the ingest of metadata with coordinates in various CRS, however, for the purpose of search, any entries whose extent is documented in other CRS should be translated for indexing into the equivalent WGS84 coordinates for parity. Otherwise, spatial search in GN will be incomplete.
Doug.
Thanks.
John
Douglas D. Nebert
Senior Advisor for Geospatial Technology, System-of-Systems Architect
FGDC Secretariat T:703 648 4151 F:703 648-5755 C:703 459-5860
Yes, the indexed bounding boxes all have to end up in the same CRS or there's not much point...
steve
Hi Francois,
will be incomplete.
Doug.
Thanks.
John
Stephen M. Richard
Section Chief, Geoinformatics
Arizona Geological Survey
416 W. Congress St., #100
Tucson, Arizona, 85701 USA
Phone:
Office: (520) 209-4127
Reception: (520) 770-3500
FAX: (520) 770-3505
email: steve.richard@anonymised.com
On Thursday, 4 March 2010 6:20 PM Francois Prunayre wrote:
Hello John,
> Hi Francois,
Of course this should be open for discussion but may I suggest that the following fields could be indexed by Lucene:
        - gml:GeodeticCRS@anonymised.com:id
        - gml:GeodeticCRS/gml:identifier
        - gml:GeodeticCRS/gml:name
        - gml:GeodeticCRS/gml:domainOfValidity/../gmd:code/CharacterString
        - gml:GeodeticCRS/gml:scope
Similarly for the other types of CRS for example, gml:ProjectedCRS.
* handle xpointer
I believe this should be done outside of the coordinate reference system selection process. It should be handled by an administrator role via another application. For example, "import and validate an CT_CrsCatalogue XML file".
create their own ?
We have taken the EPSG and excluded those coordinate reference systems that are not likely to be used by Australia and New Zealand. This will provide a pick list that is not too lengthy and more appropriate to our use.
The CT_CrsCatalogue file is available from the ANZLIC metadata profile related information web age at URL:
http://asdd.ga.gov.au/asdd/profileinfo/
The URL of the actual CT_CrsCatalogue file is:
http://asdd.ga.gov.au/asdd/profileinfo/anzlic-gmxCrs.xml
This may help in the development but won't be suitable for most people except Australians and New Zealanders. However, I think that this XML file was created by translating the EPSG GML export into CT_CrsCatalogue format. I think the XSLT to do this was developed by CSIRO in Western Australia for ANZLIC - the Spatial Information Council. They may be able to provide the XSLT for other translations with permission from ANZLIC.
future release.
That will be perfect. The more that ISO TC 211 and OGC standards are used for the implementation, storage, processing etc. the better.
Thank you very much.
John
Francois
> Thanks.
> John
>> Dear PSC members,
>> Francois
>> [2]
>> _______________________________________________
