[GeoNetwork-devel] Proposal to add text export of selected results
Dear PSC members,
I would like to propose a small feature to allow text export of
selected results. Output document could help to make quick analysis
and statistics on metadata records in a spreadsheet for example.
The complete proposal is available here [1] and patch here [2].
If motion pass, this new feature will be added to GeoNetwork trunk
(for 2.5 release).
Looking forward to your votes, Regards.
Francois
[1] http://trac.osgeo.org/geonetwork/wiki/CSVExport
[2] http://trac.osgeo.org/geonetwork/attachment/wiki/CSVExport/csv.patch
Hi François,
There is just a small "hic" with this export (experienced it myself in geocat.ch):
If there is a ";" in the abstract or elsewhere in an attribute, then the spreadsheet is "messed up". Could you use another separator, that is more unlikely to be used (e.g. a tabulator)?
Thanks
Annina
Von: Francois Prunayre [mailto:fx.prunayre@anonymised.com]
Gesendet: Dienstag, 2. März 2010 10:37
An: Devel geonetwork-devel@lists.sourceforge.net
Betreff: [GeoNetwork-devel] Proposal to add text export of selected results
Dear PSC members,
I would like to propose a small feature to allow text export of selected results. Output document could help to make quick analysis and statistics on metadata records in a spreadsheet for example.
If motion pass, this new feature will be added to GeoNetwork trunk (for 2.5 release).
Francois
Download Intel® Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs proactively, and fine-tune applications for parallel performance. See why Intel Parallel Studio got high marks during beta. http://p.sf.net/sfu/intel-sw-dev _______________________________________________
GeoNetwork-devel mailing list GeoNetwork-devel@lists.sourceforge.net
Hello Annina,
2010/3/3 Hirschi-Wyss Annina LT <Annina.Hirschi-Wyss@anonymised.com>:
True, but you could easily change that separator
Instead of
  <xsl:variable name="sep" select="';'"/>
use
  <xsl:variable name="sep" select="'&#009;'"/>
for a tab separator. I will add a comment to the patch.
But the problem remains if you have tabs in the abstract ...
Thanks for your comment.
Francois
Thanks
Annina
Dear PSC members,
Francois
Download Intel&#174; Parallel Studio Eval
I think this is a problem we always face when exporting/importing through CSV. That is also why a program like Excel will allow you to use different separators, put text within quotes etc.. Hard to avoid.
+1 from me, nice small additional functionality.
Ciao,
Jeroen
On 3 mrt 2010, at 17:08, Francois Prunayre wrote:
Hello Annina,
Instead of
use
Francois
Thanks
Annina
Dear PSC members,
Francois
[1] CSVExport – GeoNetwork opensource Developer website
[2] csv.patch on CSVExport – Attachment – GeoNetwork opensource Developer website
CSV.
The classic solution to the problem is here:
   http://en.wikipedia.org/wiki/Comma-separated_values#Basic_Rules
It's about enclosing the strings in double quotes, and escaping quotes when
needed.
+1
   Ciao,
   Emanuele
Ciao,
Jeroen
> Hello Annina,
>> geocat.ch): If there is a ";" in the abstract or elsewhere in an
> Instead of
> use
> Francois
>> Thanks
>> Annina
>> results
>> Dear PSC members,
>> 2.5 release).
>> Francois
>>------ Download Intel&#174; Parallel Studio Eval
>> _______________________________________________ GeoNetwork-devel mailing
+1 also from me (I realize its already been added :-)).
Simon
Dear PSC members,
(for 2.5 release).
Francois
geonetwork-devel List Signup and Options
